3.4 engine - Throttle body with oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cesarel, Sep 3, 2013.
  1. Sep 3, 2013 at 5:18 PM
    cesarel
    cesarel [OP] Active Member
    Cesarel
    2000 Tacoma Extended Cab 3.4
    Rancho susp
    Hello guys, i removed my throttle body 2 days ago,
    and i found this amount of oil when i removed it...
    Is it suppose to be that oily?
    :confused::rolleyes:
    Thanks for your comments in advance!
  2. Sep 3, 2013 at 6:07 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    That doesn't look too bad. Judging from the pics it's very slight. One thing you may want to do is look down the intake track. If there's oil heading 'down' towards the air filter then it's time for concern.
    My experience, i had a cracked valve cover, and a bad PCV valve coupled with some other issues that were causing excessive blow-by.
    I'm just an armchair mechanic, but i'd start by reading up on the PCV system and what it does. - And whatever you do, spend the extra $3 and buy an OEM Toyota PCV valve if you decide to replace it. The 'generic' ones are shit.
  3. Sep 3, 2013 at 7:07 PM
    cesarel
    Cesarel
    Rancho susp
    Thanks for your comment what woukd the oil going to the intake pipe?
    A bad throttle body?
    Yeah i just replaced the PCV valve for a new toyota one.
    Im changing a lot of stuff now ill post a few pics back to see if after some miles the oil there looks less or the same.
    Cheers!
