'02 taco 4x4 steering issue
Old 09-17-2013, 02:58 PM   #1
Shabutie [OP] Shabutie is offline
Shabutie is on a distinguished road
Shabutie's Avatar
Army:
Shabutie's Tacoma Gallery
Hey guys, before I bring it in I was wondering if anyone has advise. My steering is loose and making a worn out clunking sound when I go over bumps. Tie rods, ball joints and RIGHT steering rack busing all new/good. Any advice?
Old 09-17-2013, 03:00 PM   #2
Shabutie's Avatar
Army:
Note: my left bushing is unknown but I know you have to replace steering rack for that and I dont know how to tell if its messed up
Old 09-17-2013, 03:16 PM   #3
TACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shed
TACO TX's Avatar
TACO TX's Tacoma Gallery
Actually you just order a set of polyurethane energy suspension bushings which replace all 3. Replacing one doesnt fix anything.
Note: Im in the same boat and and im pretty sure the rack has had it period. They are not all that expensive to replace, you can get a refurb with lifetime warranty off ebay for like $250
Old 09-17-2013, 03:29 PM   #4
Shabutie's Avatar
Army:
Shows how much I know, I thought there was only two haha. Im crawling under it in a second. Thanks
Old 09-17-2013, 04:32 PM   #5
TACO TX's Avatar
Here is the first gen how to link, the rack bushing replacement is in here. Give you an idea where they are anyhow. http://www.tacomaworld.com/forum/1st...ful-links.html
Old 09-17-2013, 04:39 PM   #6
TIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shed
TIPICOTACO's Avatar
TIPICOTACO's Tacoma Gallery
do you still have your sway bar on? mine was clunking like crazy before I permanently removed it.
I replaced my rack bushing w/ ES ones a couple months back and it tightened up the steering quite nicely.
Old 09-17-2013, 05:05 PM   #7
TACO TX's Avatar
Well im gonna get ES sway bar bushings soon, they look pretty bad. But my rack has a lot of play in it. Think i may weld the slip joint in the column up first and see what that does before i replace it.
Old 09-17-2013, 05:05 PM   #8
Shabutie's Avatar
Army:
Ill look at it. After some looking and research my other two bushings are shot, I work for Toyota and my mechanic said they can't replace driver side bushing without the entire steering rack, so I assumed I couldn't replace it but what he meant was Toyota doesn't make them without buying the whole rack but I can buy aftermarket ones for $30, so I'm buying them and doing it my self. If that's not the problem they needed to be replaced anyway.
Old 09-17-2013, 05:07 PM   #9
Shabutie's Avatar
Army:
Yeah, it's still on. I'm not intense wheeler, just camping/hunting trips so I'm keeping it lol.
Old 09-17-2013, 05:09 PM   #10
TACO TX's Avatar
Get the energy suspension bushings from wheelers for like $18. Its not a tough job, just a few standard tools and i think i used a C clamp and a socket.
Old 09-17-2013, 05:09 PM   #11
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
This. Check the sway bar bushings for looseness. Check the end links play or rough movement.
Will these fit my 02 4x4 without issue? 1flossedTRD Wheels & Tires 4 01-31-2011 09:43 AM
ABS 02 4x4 TRD Taco saweetlou 1st Gen. Tacomas 7 12-16-2010 02:52 PM
02 TACO TRD SR5 4X4 Ext Cab Stepside OSUjake Buy / Sell / Trade - Other 3 03-27-2010 08:19 AM
02 Taco TRD 4X4 Ext Cab Stepside OSUjake 1st Gen. Tacomas 7 03-15-2010 08:45 PM
02 Taco TRD 4X4 ext cab stepside OSUjake 1st Gen. Tacomas 15 02-20-2010 08:02 AM
