tire questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by rzep1, Nov 7, 2013.
  1. Nov 7, 2013 at 8:39 PM
    rzep1
    rzep1 [OP] New Member
    tacoma 4×4
    hello there ...
    I have been running bf goodrich at/ko and need new tires
    now, factory size says 265r 70r16 but the ko's i have now are 255's..any reason for that ?? i bought the truck used.
    i have been hearing good things about the cooper at3 , which i was thinking
    about giving a shot . if i do, should i stay with the 255's or go to 265?
    im also a little confused if i should get the LT or P metric ? i really dont tow anything and every now and then will move weights and lumber but nothing too crazy . bare with me here im a newbie....:(
  2. Nov 7, 2013 at 10:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is the rest of the numbers? 255/75-17 or 255/85-16 or ??
    P-metric tires are primarily for use on pavement. LT (light truck) tires have a much more durable construction and are also heavier as a result. The type you choose depends on how you use your truck
  3. Nov 8, 2013 at 7:06 AM
    rzep1
    tacoma 4×4
    the only numbers on my ko's are 255 70r 16
    im not really doing too much off roading right now but there is some rain and snow in my future ..
  4. Nov 8, 2013 at 8:30 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    Personally, I would go with the factory 265/70/16 in an LT tire for all-around normal truck usage -- meaning mostly pavement, some light off road, carrying the occasional heavy load or towing.
    What you are running is slightly smaller and narrower. Narrower is perceived as better in many conditions, but most people would go a little taller (255/85) at the same time. This would be good for muddy conditions or aired down for rocky trail stuff. A wider tire may perform better in sandy conditions.
    But again, for general truck use, the standard size in an LT tire would be my choice.
  5. Nov 8, 2013 at 8:33 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    i run 265/75/16's BFG TA/KO and love them i go for the (LT) "D" or "E" rating because they are more durable
  6. Nov 8, 2013 at 10:18 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    D and E ratings are weight capacity, not durability. They are no more durable than a C rated. A C rated is 6 ply, a D rated is 8 ply and an E rated is 10 ply tread. This allows for greater weight capacity. The sidewall is still 2 ply rated on all 3 and the durability is the same
  7. Nov 8, 2013 at 12:59 PM
    rzep1
    tacoma 4×4
    Ok .. Thanks for the info fellas ..
    Has anyone tried the cooper at3 ??
    The tire guy is trying to pitch these
    The at / ko's have been pretty nice
    But are pretty steep for an all around tire
