Rough Idle After Valve Cover Gasket Job
Old 12-24-2013, 04:12 PM   #21
kigmob [OP] kigmob is offline
kigmob is a splendid one to beholdkigmob is a splendid one to beholdkigmob is a splendid one to beholdkigmob is a splendid one to beholdkigmob is a splendid one to beholdkigmob is a splendid one to behold
kigmob's Avatar
kigmob's Tacoma Gallery
[QUOTE=Changeling;7903611]
Originally Posted by kigmob View Post
Replaced the upstream O2 sensor and cleared the codes. All codes cleared except the P0171 code. After some searching, this codes seems to be a pain to fix. I'm guessing (since I had the whole intake apart to install the valve covers) it's a vacuum leak that I have not found yet. Any other suggestions? I plan on replacing the majority of my vacuum lines. Hopefully this helps.[/QUOT
I hope this helps, you would be totally surprised how often it is something simple causing a problem.
When you said it went away and then came back, a light went off in what's left of my brain, LOL.
It sounds to me like the "Oxygen Sensor" on the incoming air supply, right after your air filter is dirty. Listen and clean it this way using what I tell you.
Get a can of CRC electronics cleaner from just about any parts store.
Do NOT try to save a buck or so by using any other parts cleaner like break cleaner, laundry cleaner, anything else, I'm dead serious!
Now, unbolt the housing (to the oxygen sensor) right after where the air cleaner is. If unsure about where/what it is do a search on the Internet.
Once the housing is unbolted lift it out and shine a light down the tube, you will see a sensor. Looks like a bubble of plastic around a couple of wires about 1/2 the size of your little finger nail.
DO NOT STICK ANYTHING DOWN THERE AND TOUCH IT!!!
It will break and they aren't cheap!!
Now, use your can CRC (per label instructions) to spray the hell out of the sensor and and housing interior, I usually use about 1/3 of a can (can is about $5.00).
Turn it upside down and let it all drain out(BE CAREFUL, Highly Flammable) let it dry for about 30 minutes. Bolt everything back up. That's it.
Clear all codes!
The following is things that you should know:
Do this with a COLD engine (flammable stuff, CRC), don't forget this!
Do this twice a year or when you're having problems.
To totally clear codes, disconnect battery for 30 minutes.
Total time to do this (after the first) is about 10 to 15 minutes.
If it's not the answer at least it will cure a ton of other problems.
Let me know.
I actually cleaned my MAF when everything was apart. And this was not the first time I cleaned it. So it was not super dirty. Just weird it would get dirty just from sitting inside for about a day? Guess I will try to clean it a bit more thoroughly.
[QUOTE=taco47001;7903676]
Originally Posted by Changeling View Post
Um, wut? What you are referring to, is NOT an oxygen sensor. The O2 sensors are on the exhaust system measuring exhaust gas mix. By the description you gave…it seems you are referring to the Air Intake Sensor or AIT. That would have nothing to do with the code the OP is dealing with. I could be wrong though…...
He is talking about the MAF. Which I did already clean. This CAN however be the cause of a P0171 code.
Originally Posted by Loggerhead View Post
Sounds like kigmob is talking about the maf sensor. Cleaning the maf sensor will probably be beneficial.
I'm leaning towards a possible vacuum leak after taking the intake all apart. Try getting a can of starting fluid and spray it around vacuum line connections. The engine will idle up a bit if the connection is leaking.
Good luck OP! Keep us posted. . .
Im leaning towards a vacuum leak also. Just ordered a bunch of new hoses. We'll see how it turns out.
I will keep you guys posted!
Old 01-05-2014, 03:29 PM   #22
kigmob's Avatar
Got the new hoses in. Gonna install them tomorrow probably. I think I will also remove the TB and upper intake manifold, and check every bolt that holds the intake together as I reassemble. I will probably also clean my maf a bit more thoroughly. Hope this will get rid of my code. I will keep this thread updated with results.
Old 01-08-2014, 05:18 PM   #23
kigmob's Avatar
*UPDATE*
I replaced the vacuum hoses and rechecked the TB/manifold bolts. Everything seemed fine. I also cleaned my MAF thoroughly and let it dry for 30 mins before putting back in. I also added a can of sea foam to the tank to help clean out the injectors. I cleared the code and it came back within 30 minutes . I don't know what it can be. I haven't brought myself to bring my truck in to the dealer or a shop to get diagnosed. I hate doing that. It's just strange how everything is fine besides a low/chugging idle every now and again and ONLY when the engine is warm. The truck runs great when driving around. It's fine at high RPM's and has no stutter or hesitation when accelerating. Also, I've noticed the past 3 times I cleared the code, it always came back when the truck was idling, not at high RPM's or anything. Does anybody have an idea of what the problem could be? What exactly are the signs of a bad MAF sensor? Does this seem like more of an air/intake problem or a fuel problem? Thanks!
Old 01-08-2014, 09:08 PM   #24
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Clear all codes!
Let me know.
Good advice on how to clean it, however that is the MAF sensor, not an oxygen sensor.
While you have done a great job cleaning everything, that does not mean you will fix it. A faulty sensor, even one that is just slightly off, can still send slightly off data, causing an issue. I had this exact same problem with a Ford Explorer the other week. Constantly setting a P0174 code I believe. End result was the MAF sensor was bad, even though the data LOOKED correct.
That being said, was there any chance that this code was there before you started any of the work in the first place?
Old 01-08-2014, 09:26 PM   #25
kigmob's Avatar
Thanks for the reply! And no the code was not there. There were no codes prior to the work. Once the job was complete and I noticed it was idling funny, it threw 3 codes. P0130, P0133, and P0171. The first two codes lead me to believe the upstream O2 sensor was bad. I figured this was also causing the P0171. I replaced the O2 sensor and reset the CEL. The P0130 and P0133 have been gone since but the P0171 remains.
Old 01-08-2014, 09:32 PM   #26
OldPhart
bldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shed
bldegle2's Avatar
bldegle2's Tacoma Gallery
here is list of possibilities:
DTC P0171 - System Too Lean (Fuel Trim) has a number of causes. these are the more likely possibilities.
  • Air induction system. Any air leak between the Mass Air Flow sensor and the intake manifold will cause this DTC.
  • Injector blockage. You would need to do an injector balance test to determine which injector(s) are restricted.
  • Mass Air Flow Meter. This should throw a code. You can take it out and clean the inside with electronic switch cleaner.
  • Engine coolant temperature sensor. If the CTS is sending the wrong information to the PCM, it could cause the engine to run lean.
  • Low fuel pressure. You need to do a fuel pressure and volume test to check this possibility.
  • Leaky exhaust system. A leak in the exhaust system can dilute the exhaust gas resulting in a false reading.
  • Open or short in the O2 sensor wiring.
  • Bad O2 sensor.
  • A bad PCM.
Old 01-08-2014, 10:19 PM   #27
kigmob's Avatar
  • Bad O2 sensor.
  • A bad PCM.
So many things...
Old 01-08-2014, 11:02 PM   #29
egebhardt is on a distinguished road
egebhardt's Avatar
egebhardt's Tacoma Gallery
This thread is so well written, there is no way this problem can persist much longer.
I like the known-good MAF swap idea next.
Old 01-09-2014, 12:36 AM   #30
Loggerhead is on a distinguished road
Loggerhead's Tacoma Gallery
Did you use new gaskets when you reinstalled the throttle body and intake manifold? I would try to rule out a possible vacuum leak before I tried replacing sensors as they get get expensive quickly!
Old 01-09-2014, 05:51 AM   #31
Moco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shedMoco is one of the sharper tools in the shed
Moco's Avatar
Marines: 0311/0331 Security Plt. Hot dogs & Soda 2/23
Moco's Tacoma Gallery
Dumb simple suggestion....
Did you check the ECT sensor? I was doing some work around my engine (2.7L) and forgot to plug it in and my temperature gauge was dead until I looked around and found it unplugged.
In your case, the ECT sensor may cause a P0174, so its worth a double or triple check as the sensor can lay disconnected and tucked away and be a bit hard to notice.
Old 01-10-2014, 11:22 AM   #32
egebhardt's Avatar
Any updates? It would be nice to have a full story. Thanks in advance.
Old 01-10-2014, 04:16 PM   #33
kigmob's Avatar
No updates. Currently in NYC for a little vacation. When I get back I will check the ECT. I may also find a good used maf to swap out and see if that's the problem. I still just don't get how it coincidently went bad when I changed my valve cover gaskets. All I did was remove the intake and let it sit in my garage...
I would like to find someone who has some sort of live data reader so I can check all of the sensors and really see what's going on.
Old 01-10-2014, 04:21 PM   #34
once flirted with danger, danger got clingy
magikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shedmagikbean562 is one of the sharper tools in the shed
magikbean562's Avatar
magikbean562's Tacoma Gallery
same thing happened to mine when i also replaced the covers. mine was the spark plug wires were not in the right order.
Old 01-10-2014, 04:22 PM   #35
kigmob's Avatar
I replaced both intake manifold gaskets when I removed them to do the valve cover gaskets. I did not replace the TB gasket. I did dremel out the little semi circle to make it a full circle just for the hell of it. I made sure the gasket had no metal shavings hanging off so it would sit flat. I may get a new one just to be safe?
Old 01-14-2014, 08:07 PM   #36
kigmob's Avatar
So today I examined under the hood again. Everything looks good. I decided to spray a little MAF cleaner around my intake to check for leaks. I'm pretty sure I heard the engine slightly idle up when I sprayed around the TB and IAC valve. I'm thinking my IAC valve gasket may be leaking. I did not clean or check the IAC valve when I cleaned the TB. I'm thinking I may have caused a leak when I was pounding the TB with cleaner. I think I'm gonna pull the TB and replace the TB gasket along with cleaning the IAC valve and replacing its gasket as well. I will also check everything else while it's apart. I sure hope this fixes it. I will keep you guys posted. Anyone know the part numbers for these gaskets?
Old 01-17-2014, 08:23 PM   #37
kigmob's Avatar
*Update*
So my problem may be fixed. I took off the IAC valve and cleaned it. I also connected it to be battery directly to ensure it was working properly (I checked it before I cleaned it and it worked fine). The old gasket looked fine as well. I was beginning to think this would not fix my problem. I noticed when I pulled off the old TB gasket that it was not oriented correctly. Maybe this could have been my problem? Anyways I put the new gaskets on and pulled the efi fuse for about 15 min. When I started the truck it started strong and slowly idled down to about 750 rpm. It remained here and did not drop low to 650 rpm like it used too. No CEL as well (still haven't driven enough to know for sure if it will come back). I hope this fixes my problem. I will update this thread once I know if it is fixed for good.
Old 01-18-2014, 05:55 AM   #38
Moco's Avatar
Good info. Thanks for the update. Let us know if its stay good.
Old 01-21-2014, 02:35 PM   #39
kigmob's Avatar
Seems to be fixed for good. No CEL. Must have been the TB or IAC valve gasket. Thanks for the help guys!
What to do about leaking valve cover gasket? Yoshio Technical Chat 21 12-15-2014 05:36 PM
Valve Cover Gasket Advice kigmob 1st Gen. Tacomas 11 11-27-2013 07:39 PM
Valve Cover Gasket Leak? bustedflyrod 2nd Gen. Tacomas 65 12-15-2012 12:31 AM
valve cover gasket leak alberto_seattle 2nd Gen. Tacomas 0 02-20-2012 04:18 PM
valve cover gasket????!! tacomaforlife 1st Gen. Tacomas 10 03-01-2011 06:14 PM
