Running wire through back cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockTock, Jan 13, 2014.
  1. Jan 13, 2014 at 1:28 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    I am installing 'manually' activated backup cam and alarm, and I can see wires between the cab and the bed, but I have a liner, and can't see how to run wires, or where they go into the cab and how to pull them in? Anyone do this before (with any kind of install?) -(1999 Tacoma 2wd X-cab)
    No this is not how your 'supposed' to do it. The video screen will be removable and all etc. :eek: Its just getting wired into the cigarette lighter.
  2. Jan 13, 2014 at 5:38 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Is it an extra cab? If so the passenger side bottom right of the cab will have a rubber plug that when pulled out will gain access to the inside of the storage compartment under the rear passenger seat. Make a slit in the rubber plug and run your wires through there.
  3. Jan 13, 2014 at 5:44 PM
    RockTock
    Colorado
    Yes, I should have said need to run the wires under the bed, so the access panel at the BACK of the cab, going outside, is on the left hand side? I can see some wires in the gap back there, but it looks more toward the middle.
  4. Jan 13, 2014 at 5:50 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Are you asking is that where the hole is or are you telling me that's where you want the wires to come out. I'm confused as hell right now lol
  5. Jan 13, 2014 at 6:48 PM
    RockTock
    Colorado
    I'd like the wires to go out where there are already wires going out. It's definitely in the center of the back of the cab. I don't think there is an exit panel underneath the bench though. Crap.
    Im trying to run the video and power cable for a back up camera, if that helps. I will be plugging it in manually to my 12v outlet.
  6. Jan 13, 2014 at 6:56 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Run your power cord under the centre console. Under the passenger seat up into the storage under the rear passenger seat. Put through the rubber grommet in the cab. Along the frame rail and your done.
  7. Jan 13, 2014 at 8:06 PM
    RockTock
    Colorado
    Ok, I'll check that out, thanks
  8. Jan 14, 2014 at 12:41 AM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    you have to remove your rear seats and rear panel to get to the hole. the harness probably runs on one side and splits off in the rear for the tail lightsand license plate light. I havent ran anything back there yet but that makes sense. You could always do in reverse and follow the wires from your tail lights or license plate light all the to the front. you wont be able to see the run with a bedliner there or not. wires are most likely run through the body. silicone what ever hole you make in the grommet so wont water cant get into the vehicle.
  9. Jan 14, 2014 at 6:35 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    On my '97 there was a rubber grommet below the driver's seat that worked for me. I went under the bed along the frame.
  10. Jan 14, 2014 at 9:30 AM
    RockTock
    Colorado
    I like that, I think they are the same body. PITA to take out the rear seats and stuff.
  11. Jan 17, 2014 at 6:35 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Under driver seat easiest way
