need some quick insight
Discussion in '1st Gen. Tacomas (1995-2004)' started by hobbs311, Feb 9, 2014.
  1. Feb 9, 2014 at 9:02 PM
    hobbs311
    hobbs311 [OP] Well-Known Member
    Texas
    SR5, super clean =)
    Sorry i know this is the wrong forum but its related to the tacoma. I might buy an 01 4runner tomorrow and it has the v6 with the auto trans. Same drive train as the first gen tacomas? anyone know of any down sides to the 4runner. any input would be appreciated
  2. Feb 10, 2014 at 12:35 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Had 97 4-runner with 6 cyl and auto trans. Had to run with ect button on full time for any decent performance. Great snow vehicle though.
  3. Feb 10, 2014 at 1:00 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    yes, same transmission. good for 300k with regular maintanance.
  4. Feb 10, 2014 at 4:17 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    They had a lot of trouble with their Radiators. The Transmission fluid would mix with the Coolant and wreck the transmission. Pay special attention to the transmission fluid and check if the vehicle has a new radiator. If it has a new radiator either the old one got corroded with possible transmission damage or it was changed as a preventive measure.
  5. Feb 10, 2014 at 4:21 AM
    Sin
    Superior, Wisconsin
  6. Feb 10, 2014 at 4:21 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    If it hasn't been changed, don't let that scare you. There is a TON of info on the dreaded "pink milkshake" and what steps to take to prevent it…..
  7. Feb 10, 2014 at 4:21 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  8. Feb 10, 2014 at 5:40 AM
    hobbs311
    Texas
    SR5, super clean =)
    So what causes this? just wear over time or the environment its in, ie. snow ice salt, for the lines to corrode. This is the first of me hearing it. What are some signs to look for when looking at a 4runner. Going to look at one before lunch so any and all input is great. thanks guys.
  9. Feb 11, 2014 at 11:23 AM
    dbd
    dbd Well-Known Member
    Dave
    WV
    2003 Tacoma 4x4 5spd
    2" leveling kit
    Check coolant and transmission fluid. New? Clean? Radiator new? Service records? Timing belt due at 90,000. All in all good vehicles. 5 spd are awesome, auto's ok. Turn off ect button for more power. Great in 4wd. Check for rusted frame. Easy to lift with 2" lift springs or spacer kit. Good luck.
  10. Feb 11, 2014 at 11:25 AM
    dbd
    Dave
    WV
    2" leveling kit
    The coolant and trans fluid use the same radiator and the internal wall can fail and cause them to mix. Coolant will trash the trans. Read the strawberry milkshake thread.
