Lift height with 1.5" on top of the strut plate spacer
Old 03-28-2009, 07:55 AM   #1
Whitfield [OP] Whitfield is offline
Whitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shedWhitfield is one of the sharper tools in the shed
Whitfield's Avatar
Whitfield's Tacoma Gallery
How much lift will a 1.5" on top of the strut plate spacer give me.
about 2" ~ I'm guessing
Old 03-28-2009, 09:33 AM   #2
SRFIVE is a glorious beacon of lightSRFIVE is a glorious beacon of lightSRFIVE is a glorious beacon of lightSRFIVE is a glorious beacon of lightSRFIVE is a glorious beacon of lightSRFIVE is a glorious beacon of light
SRFIVE's Avatar
SRFIVE's Tacoma Gallery
Mine was just as advertised; 3" on stock springs and stock weight front end. You could calculate the actual lift if you knew your spring rate and the weight of your front end.
Old 03-28-2009, 03:20 PM   #3
Whitfield's Avatar
1.5" spacer gives 3" of lift? WoW!
I knew that the leaver design of the front end would give more then then the spacer but I had no idea it would double the height.
I bought it as a 3" Lift spacer ~ but expected it to be 2.5"
Looks like my Nooby is showing
How much lift w/ 5100 set 0 and Eibachs w/ 1/4" top plate spacer driver side Gabe911 Suspension 7 01-30-2012 08:34 PM
1/4" Toytec top plate spacer (provides 1/2" lift) for taco lean ds46000 2nd Gen Tacoma Marketplace 10 03-03-2011 12:14 PM
1/4" Toytec top plate spacer (provides 1/2" lift) for taco lean ds46000 2nd Gen Tacoma Marketplace 8 02-16-2011 03:06 PM
top plate spacer lift l_prettyman Suspension 18 05-11-2010 07:57 PM
FS: Daystar 1.25" Top Plate Spacer Kit w/ Top Coil Plates and Studs Neubs Buy / Sell / Trade 13 01-23-2009 08:45 PM
