E brake problem after block lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shortman5, Mar 30, 2014.
  1. Mar 30, 2014 at 9:59 AM
    Shortman5
    Shortman5 [OP] Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    So I wanted my truck to sit level so I took out my add a leaders and put on a 1.5 block to make it level with the front. When I got home I noticed my e brake cables were strung over the leafs. I thought there would be a fix since these were made for the first gen Tacoma but nothing works. Help?
  2. Mar 30, 2014 at 10:02 AM
    Shortman5
    Supercharged TRD
    Should I just leave then disconnected until I can find a fix so I don't wear my drums out while I drive? The red parking light does not come on until I pull the brake but I can tell it definitely is a shorter distance to pull out.
  3. Mar 30, 2014 at 10:07 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
  4. Mar 30, 2014 at 10:09 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    That won't help with the Ebrake cable, but it's not a bad idea to get one.
    There's a Ebrake adjustment under the truck on the drivers side frame, you can make some slack there, and that should help some.
  5. Mar 30, 2014 at 10:33 AM
    Shortman5
    Supercharged TRD
    Is that all I can do? Just leave them going over the top of my leafs?
  6. Mar 30, 2014 at 10:38 AM
    95 taco
    95 taco Battle Born
    In theory you could build a extension that bolts or welds onto the little arm on the drum, and have it move the mount up.
    It's never been tried before as far as I know, but in theory it's possible.
  7. Mar 30, 2014 at 10:41 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    from the photo, it looks like there is a BPV extension...
    along with the slack in the line, look into extending the bracket circled below to help guide the brake line a little higher so it's not sitting like that on the leaf packs...
  8. Mar 30, 2014 at 11:33 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    You could replace those blocks with a 1" block (or whatever size will eliminate the cable problem, and then use longer shackles for the additional needed lift.
  9. Mar 30, 2014 at 3:59 PM
    95 taco
    95 taco Battle Born
    Hmmm, his E-brake cable is set up differently than mine.
  10. Mar 30, 2014 at 4:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Some more thoughts.......
    1) Another thought.... take that top piece off (in the photo) and bend it upwards in a vice (if possible).
    2) Another thought.... build a new piece that has a bend in it - just make sure you include rubber to 'sheath' the cable because it will rub at that location
    3) Put spacers between those two pieces to lift it upwards.
  11. Mar 30, 2014 at 4:10 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Yup 03-04 is under the leafs.
  12. Mar 30, 2014 at 6:26 PM
    mkatts
    mkatts Well-Known Member
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    Look at this from Tejasyota...
  13. Apr 1, 2014 at 7:50 PM
    Shortman5
    Supercharged TRD
    Ok thanks for all the response y'all. I'm probably just going to make some brackets to get them off the spring.
  14. Jan 15, 2016 at 12:42 AM
    Bern
    Bern Well-Known Member
    Western wa.
    Idk if uve solved this dilemma by now but i just unhooked mine and routed them under my leafs and works fine takes 2 minutes literally
  15. Jan 15, 2016 at 1:38 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    Thread revival eh? I have the same issue. I WAS going to drill a hole in the arm on the hub, at a lower point, and reattach the pin there. But I've since ignored it. Doesn't seem to be affecting anything. Have left it that way for over 3 years since I bought it. New leafs and lift in the near future anyways. But figured my idea might be an easier option for y'all.
  16. Jan 15, 2016 at 10:55 AM
    Bern
    Western wa.
    U literally only have to take the pin out of the bracket cable comes off go underneath and wam no drilling moding needed
  17. Jan 15, 2016 at 1:16 PM
    NightProwler
    Harlan
    Maricopa, Az
    Yeah mine is routed under, but is still arched. Not as bad but figured I'd throw that out there if anyone still had that issue after rerouting like mine and wanted an easier fix rather than fabricating new cable brackets like someone suggested.
