1998 Tacoma: The Two 12v Auxilliary Outlets Under The Ashtray - One is not functionin
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Apr 8, 2014.
  1. Apr 8, 2014 at 11:00 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    So this has been bothering me for awhile. I'm talking about these outlets
    bde15d6f-75dd-49d7-a9f4-1581950234ff_zps_2ffb0d78f79841a084c96c78ce17a39974d1f653.jpg
    Ever since I took my lower dash apart to paint it, the outlet on the right (passenger side) has not worked since reassembling.
    The wiring harness can only clip on one way, and yes it is attached.
    Are these two outlets on separate fuses? It's just strange that the left one works and the right one doesn't.
    Any advice or troubleshooting is greatly appreciated.
  2. Apr 8, 2014 at 11:08 AM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
    sub'd
    i have the same problem on my 98 and i'm terrible with electrical problems
  3. Apr 8, 2014 at 11:37 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Swap lighter elements. Follow the 2 wires from the defective receptacle back to where it joins the connector and make sure you have a good connection, both in back of the receptacle and in the connector itself.
  4. Apr 8, 2014 at 11:56 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Like said above you can swap the wires on the back of the two receptacles to see if the problem follows or just test the wires with a meter to see if its getting 12v. If it is then its the receptacle. If not then the next thing would be to use the meter to check the continuity between the ends of the wires to tell you if it has a wire that got cut or pulled apart somewhere. I imagine the wires Y to go to both receptacles somewhere and if it isn't a bad one then the wires pulled loose from the Y.
