How much can I stick in my bed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgen, Jun 9, 2014.
  1. Jun 9, 2014 at 7:28 PM
    1stgen
    1stgen [OP] Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    I've read a few threads but none were for 2001-2004 1st gens. Can I stick a 600# fourwheeler in the bed of my truck? Stock leafs and 5100s in the back. How much am I going to sag? Thinking about hauling my friends out to ride.​
  2. Jun 9, 2014 at 7:53 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Highly doubt an ATV can fit between the wheel arches in the bed. Take a look at my signature pic. That's 12 sheets or 3/4 plywood. Don't know exactly how many lbs it is, but roughly the same if not more as your 600 lb atv. That's about how much it will squat. *Edit: Forgot you have upgraded rear shocks. Will squat less
  3. Jun 9, 2014 at 8:27 PM
    1stgen
    18 SR5
    I'll have to ask for measurements, hopefully it will work.
  4. Jun 9, 2014 at 8:39 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    600 pounds is a piece of cake.
  5. Jun 9, 2014 at 8:41 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Upgraded shocks do nothing for supporting weight. Only give a better quality ride. Leaf springs are what support the weight in the rear.
  6. Jun 9, 2014 at 8:42 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    what he said.
  7. Jun 9, 2014 at 8:42 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I've have over 1000 lbs of scrap steel in my bed and I was an inch away from the bumps. And I'm on really bad worn leafs. Also, shocks don't do anything to boost load capacity. That's all leaf spring. Shocks just prevent bounce
  8. Jun 9, 2014 at 8:45 PM
    CNEDEER
    CNEDEER If ya ain't first, your last!
    2015 DC TRD OR 4x4
    Yes an atv will fit in the back of it. I have a 1st gen and just bought a Grizzly 660. Its tight, but it fits:D
  9. Jun 9, 2014 at 8:55 PM
    1stgen
    18 SR5
    He has a brand new Honda Rancher, do you have the bed up or down?
  10. Jun 9, 2014 at 9:04 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I hauled an older Honda. I think it was a foreman 400? It fit fine. Just be carful about the back glass( used a piece of 4x4 between the four wheel and back of bed) and don't press it too hard against the back of the bed it is weak and will bend. I also have shocks and leafs that are very worn out and it seemed to do fine, but it wasn't a very big or fourwheeler.
  11. Jun 10, 2014 at 5:12 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    That wood is 900lbs in my pic plus some concrete underneath that so I'll say over 1000 lbs. 600 should be no issue. You can roll with the tailgate down if it cant fit in between the wheel arches. Just make sure to strap it down good.
  12. Jun 10, 2014 at 5:49 PM
    WThomas1250
    WThomas1250 Well-Known Member
    The weight isn't an issue at all. My Honda 250cc just fits though. So you may have an issue with it fitting
  13. Jul 20, 2014 at 3:22 PM
    HomerLovesFire
    HomerLovesFire Well-Known Member
    Hagerstown, MD
    09 PreRunner SR5 TRD Off-Road
    My 2014 Polaris 570 fits in the back just fine. Only issue is I can't put the rear tailgate up. Other than that the truck rides great With no issues.
  14. Jul 21, 2014 at 9:09 AM
    bguenth17
    bguenth17 Member
    Brian
    Baltimore
    '97 Tacoma
    Foreman 500 in back of a 97
  15. Jul 21, 2014 at 9:54 AM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I've had my 91 Suzuki 250 (my google fu says it's about 500 lbs) parked on a 1/3 bed full of wood with coolers of beer and two chicks inside with me. At the time had stock leafs and lift shackles and 255/85/16s. I couldn't put my foot between the tire and fender... :eek: Had a short maybe 10 mile drive like that.
    Still running those leafs today.
  16. Jul 21, 2014 at 12:14 PM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    If you can fit it in the bed, it will be just fine. Just be careful depending on the terrain you are driving on. I hauled a lot of firewood last year in my tacoma on some pretty rough roads and it was fine. I have dakar leafs in the rear.
  17. Jul 21, 2014 at 3:46 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Not sure what brand/model of the 4-wheeler (not mine), but it fit with the tail gate up. :D
