5 spd trans won't go into 1,3,5
Old 07-09-2014, 01:46 PM   #1
bwheat1 [OP] bwheat1 is offline
bwheat1 is on a distinguished road
bwheat1's Tacoma Gallery
I have a 1995 Tacoma with a 5 speed manual transmission and it wont go int 1,3, or 5th gear but it goes into 2 and 4th just fine could somebody tell me where to start.
Old 07-09-2014, 02:34 PM   #2
dispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the sheddispatch55126 is one of the sharper tools in the shed
dispatch55126's Avatar
Firefighter:
dispatch55126's Tacoma Gallery
Since you live where you live...
Seriously though, when is the last time you changed your gear oil? Mine was difficult getting into 1st and 3rd and after changing the oil, shifting is much easier. Beyond that, it could be your shifter seat not allowing you to fully shift in that direction.
Old 07-09-2014, 02:43 PM   #3
XR1200 is on a distinguished road
XR1200's Tacoma Gallery
Synchros could be shot. I had a Mitsubishi truck that lost 3rd and afterdraining the fluid and seeing too many metal flakes and then taking off thecover allowed me to see a synchro that had broken apart. However, in your caseit may not be a synchro but a shift fork, can also be a shifter ball that has disintegratedcausing too much slack, which can cause engagement issues.
Drain the oil into an empty pan and look for foreign material like brassflakes and/or pieces.
Old 07-09-2014, 03:05 PM   #4
Master of all I survey.
Indy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shed
Indy's Tacoma Gallery
Hmmm, that's odd.
Old 07-09-2014, 03:27 PM   #5
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Common result of a shift rail issue, or detent ball. However extremely dirty trans fluid can cause issues like this as well. Is it just really difficult to get it in those gears, resulting in you having to force it, or will it just not go in those gears at all, any time? (driving, sitting still, engine on or off, etc)
Old 07-09-2014, 04:30 PM   #6
Found it, it was the plastic bushing on the end of the shifter. Thanks for the comments though.
Old 07-09-2014, 04:52 PM   #7
Firefighter:
Marlin Crawler makes a replacement cup made out of a more durable material.
2006 Tacoma 4.0 6 spd won't shift?!! dpanibratets Toyota Trucks & SUVs 1 06-26-2014 12:54 PM
Shifter keeps coming out of 6 spd trans hudhawk 2nd Gen. Tacomas 11 12-15-2011 10:28 PM
%spd man trans swap with second gen 6spd fujitacoma01 1st Gen. Tacomas 3 02-01-2011 11:25 AM
4 spd vs 5 spd auto trans fireroad 2nd Gen. Tacomas 4 09-23-2010 07:58 AM
09 5 spd auto trans observation emmitt 2nd Gen. Tacomas 4 10-31-2009 08:59 PM
