Rerouted my AC drain tube
Old 07-09-2014, 05:40 PM   #1
20vmki [OP] 20vmki is offline
20vmki is on a distinguished road
20vmki's Avatar
20vmki's Tacoma Gallery
While poking around under my truck I saw that one of my sway bar bushing bolts was quite rusty while the other one was just fine. I found that AC drain tube was dripping right onto the frame and the water was finding its way down to the screw, overtime causing the rust.
I went to my local ACE Hardware (LOVE that place) and found a replacement bolt (head was 13mm instead of 12mm, but it still worked), M8x1.25x35mm with a 8mm washer.
Next I got some 3/8in ID (inside diameter) tubing, about 3 feet of it, and slid it over the drain tube, securing it with two zip ties. I then routed it down the frame where it could drip onto the ground. I just have to check on the hose to make sure it holds up to the engine bay temps (it sits kinda close to one of the exhaust manifolds).
Old 07-09-2014, 07:12 PM   #2
I have a problem for your solution…
Snowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shed
Snowman's Avatar
Snowman's Tacoma Gallery
That's cool, but if I replaced every rusty bolt under my truck it would mean replacing everything. haha
I think most new bolts here are a bit rusty to start with.
Old 07-09-2014, 08:25 PM   #3
Area51Runner is on a distinguished road
Area51Runner's Avatar
Area51Runner's Tacoma Gallery
nice one thx for posting.
AC Condensate drain ? JoeN 267 2nd Gen. Tacomas 37 10-26-2014 02:08 PM
UnderCover Flex Drain Tube Mod [FX41003] Jooce 2nd Gen. Tacomas 6 09-07-2014 03:10 PM
Where is the AC evaporation drain located? Madjik_Man 1st Gen. Tacomas 26 08-30-2014 07:53 AM
Ac drain line causing rust? magnum922 2nd Gen. Tacomas 6 08-14-2011 09:25 PM
AC Evaporator Drain Got Tacoma 2nd Gen. Tacomas 1 12-09-2009 05:11 PM
