Drum replacement = pad replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Polar6667, Jul 10, 2014.
  1. Jul 10, 2014 at 7:06 PM
    Polar6667
    Polar6667 [OP] Member
    Washington
    2000 Tacoma TRD
    I've looked all over these threads so if this has been answered/discussed, my apologies. Please point me in the right direction.
    Here's my problem/question: My 2000 Taco has had a pulsing in the seat, not steering wheel when braking, and has been diagnosed as warped drums. With 170k miles on the truck and these being the stock drums it stands to reason. A couple years ago I had blown axle seals, grease, etc... The rear brakes were done at that time and the drums were turned (hence the warping), new pads were installed at that time.
    I purchased a pair of Centric drums and replaced them yesterday only to have the vibrations to be worse than the warped drums.. Did I get a bad pair of drums? Is it necessary to replace the pads due to the old drums being warped? Do Pads conform to warped drums thus vibrating worse on a smooth surface?
    Thanks for any help..
  2. Jul 10, 2014 at 8:57 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    I had a terrible past history with other than oem drums. Exactly as you described. I have always heard to replace shoes with new drums. Not an expert here though. GL
  3. Jul 10, 2014 at 9:00 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    "Do Pads conform to warped drums thus vibrating worse on a smooth surface?"
    Yes they will. Replace the pads, should be a world of difference.
  4. Jul 11, 2014 at 6:09 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'd get new shoes in there ASAP before they wear the drums unevenly to match them being worn unevenly. I'm also a believer in changing pads/shoes when you change rotors/drums.
  5. Jul 11, 2014 at 7:39 AM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I've always been of the understanding that shoes/pads will wear into the drum. I've replaced rotors without replacing pads and drums without replacing shoes and never had a problem... Until the shoe wore out and fawked up an almost new drum with 20-30k on it. I was too broke when I replaced drums for even the cheap $20 shoes. :eek:
    Edit: if the shoe has huge noticeable grooves replace it. If looks pretty smooth I would run it in a bind.
  6. Jul 11, 2014 at 8:54 AM
    Andy.G
    Andy
    Virginia
    The shoes are so cheap,why take a chance. Have a feeling it's the drums though.
  7. Jul 11, 2014 at 11:11 AM
    Polar6667
    Washington
    2000 Tacoma TRD
    That's pretty much what I thought. I had changed the drums back to the old ones till I knew more. I'll get some pads and do the whole job. A shame since there is so much left on the pads but that's the miser in me.
    Thanks for the responses!
  8. Jul 11, 2014 at 11:16 AM
    MowTaco
    Kansas
    Yeah it can be painful... Get some that have a lifetime warranty on them. No they're not the best pads but they stop me just fine and you can just replace whenever. I roll on Oreilly brakebest select currently, just replaced them a few months ago since I warped my rotors. It eases the pain of replacing stuff with lots of life left when it only costs you time :)
  9. Jul 13, 2014 at 9:36 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    New drums, new shoes. If the surfaces are not mating correctly you will develop hot spots. This warps drums and glazes shoes. Same with pads and rotors.
  10. Jul 25, 2014 at 8:58 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    Doing the job this week. I'll report back on my success or failure. 1st time doing drum brakes. Wish me luck...
  11. Jul 28, 2014 at 9:42 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    All done and I'm surprised at how easy it was! The pulsing is all gone and it's smooth sailing. Thanks again for the replies!
  12. Jul 31, 2014 at 6:11 AM
    LAL00O00
    LAL00O00 Well-Known Member
    Jorge
    San Diego, CA
    2001 TRD Taco
    What drums did you go with? Looking replace mine also but price range is 30 to 150 so im unsure of the quality and the description fails to describe them
  13. Aug 7, 2014 at 8:02 AM
    Polar6667
    Washington
    2000 Tacoma TRD
    Sorry for the late reply, not getting the notices... I got Centric drums and shoes from rock auto. $31 for the drums (ea) and $17 for the shoes (as a set).
    However the problem continued soon after my last post. The drums, new ones, were out of round... Waiting for the replacements to arrive. Hope my new shoes weren't damaged by the crap drums. Only drove for a couple days..
  14. Aug 7, 2014 at 10:38 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    I wouldn't be too concerned about the shoes. If you only spent $17 for the set, then they are also crap. I was having problems with grabbing brakes in the rear, and replace the shoes with OEM ($110). Now, they are smooth as silk.
  15. Aug 7, 2014 at 12:20 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    Huh, I thought centric was pretty good and that rock auto.com just had great prices. I didn't buy the cheapest ones.
  16. Aug 7, 2014 at 6:12 PM
    Andy.G
    Andy
    Virginia
    Oem drums only on mine after going threw same problems you are having. Hope your new ones hold up.lol
  17. Aug 8, 2014 at 7:31 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    Damn.... Me too.
