Leaking pumpkin!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tiki Tacoma, Aug 7, 2014.
  1. Aug 7, 2014 at 2:10 PM
    Tiki Tacoma
    Tiki Tacoma [OP] Well-Known Member
    CT
    03 dbl cab trd
    I read threw some other threads pn this topic but none were helping me so i decided to post my first thread on the site.
    Basically i looked under my truck to check out my shocks and noticed a stain forming. After looking closer it seems my pumpkin is leaking fluid, and i cant tell where its leaking from, there might even be a hole from rust. I dont know much about cars but im freaking out over this! ive ha the truck no more than 5 months ! Ive been trying to read as much as i can about the subject but i figured id ask the TW experts for some advice on where to go from thais point. here are some pics
    Any help is much appreciated thank you!
  2. Aug 7, 2014 at 2:13 PM
    Large
    Large Red
    If it's leaking it's coming from the fill plug. Remove the fill plug and wrap it in teflon tape for a quick fix.
  3. Aug 7, 2014 at 2:16 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    Should i refill i while its open?
  4. Aug 7, 2014 at 2:17 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    X2. Looks like the fill plug is the origin of the mess...
  5. Aug 7, 2014 at 2:19 PM
    Large
    Large Red
    The 'full' level would be when fluid starts coming out of the diff, the fluid you see there might just be from a recent change from the previous owner. Wipe it all off and drive 50 miles or so and see if there is any noticeable new fluid coming out.
  6. Aug 7, 2014 at 2:24 PM
    grillmaster
    grillmaster Active Member
    Texas
    2014 DCSB SR5 TSS Sport
    Get a new plug and applicable washer if any. If no washer use the teflon as previously mentioned. Also, you can check if it's low and refill as necessary.
    Clean the outside of the pumpkin thoroughly. You want to have a benchmark to refer to for when you check periodically until sure it's stopped leaking.
  7. Aug 7, 2014 at 2:38 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    Thanks guys! Much appreciated
  8. Aug 7, 2014 at 3:10 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yea, as others have said, get a can of brake cleaner and clean it very well, then drive, look for where its leaking (99% sure from the plug) and put a new gasket on the plug or some tape on the threads. i would change out the plug for one of the magnetic ones
  9. Aug 7, 2014 at 3:58 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    Yeah i cleaned it good and it looks like that plug is leaking. Where can i find a magnetic one?
  10. Aug 7, 2014 at 4:06 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
  11. Aug 16, 2014 at 12:34 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    So i pu in a new plug And its still leaking...
  12. Aug 16, 2014 at 12:53 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Mine was leaking too one time. The gasket had gone bad. A local shop sealed it up for 40 bucks IIRC.
  13. Aug 25, 2014 at 3:43 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    Got a new crush gasket and drain plug, wrapped it in teflon tape and it still seems to be leaking.
  14. Aug 25, 2014 at 4:03 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Your first picture looks to me like you're leaking from the top area.... maybe the vent?
    If it leaked at the plug, there should be no oil above it, but there is.
    .. that's how I see it, YMMV.
  15. Aug 25, 2014 at 6:05 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
  16. Aug 25, 2014 at 10:22 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    That second photo shows what appears to be a small crack in the housing, just above the fill plug. Do you have a new photo of the housing all cleaned up?
  17. Aug 25, 2014 at 10:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I see a hell of alot of corrosion/rust, some mentioned seeing a crack as well , don't know how mech. you are but I'd start by getting some aerosol carb/choke cleaner or brake cleaner (reason for this is to strip any petroleum based shit (like diff/gear lube) off & around the filler hole area plus it dries quickly, then get ya some safety glasses & maybe a med./semi course wire wheel on a cordless drill & start knocking that shit off till you can at least see if theres holes/cracks in what seems to be an obvious corrosion area, does the rest of your under carriage look anything like that ??
  18. Aug 25, 2014 at 10:39 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
  19. Aug 26, 2014 at 4:42 AM
    Tiki Tacoma
    CT
    03 dbl cab trd
    Its pretty bad under there in some spots, i live in a area where we get a gold amount of snow and its by the ocean. Ill clean it up and take a
    New picture, but unfortunatley i dont know a thing about welding
  20. Aug 26, 2014 at 5:25 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    JB weld FTW!
