Leak from oil filter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnboyTRD, Aug 12, 2014.
  1. Aug 16, 2014 at 10:30 AM
    #21
    johnboyTRD
    johnboyTRD [OP] Well-Known Member
    John
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Grrr I think I still have a leak somewhere, but it seems more watery than oil. Tomorrow is car maintenance day, so I'll take a closer look then.
  2. Aug 17, 2014 at 7:02 AM
    #22
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Watery vs. oil sounds like antifreeze...pressure washer and talcum powder often helps.
    Howard
  3. Aug 17, 2014 at 8:49 AM
    #23
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    A cooling system pressure tester tool will help in locating a coolant leak, if the leak is coolant.
  4. Aug 19, 2014 at 7:17 PM
    #24
    johnboyTRD
    John
    South SF bay
    Ok so I am an idiot... The watery stuff... Was water from me spraying down the sliders (facepalm). No leaks. Thanks dudes.
