Stock Tires are Rubbing
Old 08-24-2014, 09:06 AM   #1
madcapsuess is on a distinguished road
madcapsuess's Tacoma Gallery
When I turn the wheel I can hear my tires rubbing, everything is stock. Is this a normal thing? If not, any ideas?
Old 08-24-2014, 11:18 AM   #3
Originally Posted by License2Ill View Post
Where on the vehicle is the tire rubbing?
My front tires are hitting the plastic in the well. I'm thinking I should lift the front up and inch or two. That way I can level the truck out and get rid of the rubbing.
Old 08-24-2014, 11:20 AM   #4
Ditch Doctor
medic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shed
medic2230's Avatar
EMS:
medic2230's Tacoma Gallery
What size tires are you running?
Old 08-24-2014, 12:01 PM   #5
265/70 R16. Stock.
Old 08-24-2014, 12:08 PM   #6
Ditch Doctor
medic2230's Avatar
EMS:
Front springs worn out and sagging?
Old 08-25-2014, 07:20 AM   #8
Hillbilly
Fenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shed
Fenwick1993's Avatar
Fenwick1993's Tacoma Gallery
If everything is stock, and you're in a 2002, check your springs. Truck is old enough to where depending on how it is treated, they may be ready to give.
Old 08-25-2014, 07:30 AM   #9
hetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shedhetkind is one of the sharper tools in the shed
Army: Defense Contract Management Agency
hetkind's Tacoma Gallery
I would suspect worn front coil springs, the truck would be about 12 years old and they tend to sag over time.
I believe Monroe sells what they call a "quick strut", a built up shock and spring assembly, ready to install for about $100 per side or the cost of a Bilstein 5100 adjustable.
Howard
Old 08-25-2014, 11:17 AM   #10
Master of all I survey.
Indy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shedIndy is one of the sharper tools in the shed
Indy's Tacoma Gallery
You can get complete assemblies from a few different places. The front end sag seems like a common issue. If I was swapping for stock and had the 2.7 I might end up going for the the 3.4 struts/springs instead. They *should* be set for a little extra weight and *might* be a stiffer ride until they break in, but I'd guess they will hold up longer than the lighter springs. And the taco doesn't exactly ride like a 70's cadillac in the first place.
I'm going for tundra's myself, waiting for them to show up at the house now. I've got a heavy front bumper/winch and the sag was noticeable before, same rubbing issues on the drivers side. It's gotten worse since I added the extra weight and even the passenger side rubs from time to time. Ideally, I'd like to be able to shift the front axle an inch forward but I don't think that's much of an option with IFS.
Rubbing with stock tires madcapsuess 1st Gen. Tacomas 0 08-23-2014 09:37 PM
*HELP* tires are rubbing mendoza166 2nd Gen. Tacomas 10 08-22-2014 03:26 PM
New tires + stock 04 DC = rubbing. Need advice mjhenks Suspension 8 03-06-2012 10:36 PM
Rubbing with Stock Tires and Stock Height? tacomtn 2nd Gen. Tacomas 7 09-09-2011 04:53 PM
rubbing tires polartoy New Members 0 02-04-2011 06:53 PM
