airbag light....
Old 09-02-2014, 06:34 PM   #1
Toyota4x46921 is on a distinguished road
Toyota4x46921's Tacoma Gallery
airbag light....
I have searched the boards for a while on this topic. A few weeks ago my airbag light came on. I checked pretty much everything I could to make sure all connections are connected. I don't want to pay for the dealership to run the computer on it. My horn still works so I wasn't sure if it could still be the clock spring. I also read about a seatbelt retractor that could be bad? I cannot find much on that topic. Any help would be appreciated. I have an 04 Tacoma by the way
Old 09-03-2014, 05:00 PM   #2
bry838 is just really nicebry838 is just really nicebry838 is just really nicebry838 is just really nice
bry838's Tacoma Gallery
I had a nasty air bag light problem here a while back couldn't figure it out fur nothing!! Ended up being my phone charger plugged into the cig lighter!! Not the accessory plugs but the cig lighter! Pulled it out and boom the light was gone! Hopefully you got the same thing going on??
Old 09-14-2014, 05:14 PM   #3
sunset1212 is on a distinguished road
sunset1212's Tacoma Gallery
You mentioned you checked the connections. .. did you check the ones going to the SRS/airbag computer? My light taunted me for years, couldn't figure it out after running the diagnostic checks. I read once on this forum that someone wiggled the wires running tothe computer and That's What I did...it's been a month and no light!
Old 09-16-2014, 08:53 PM   #4
Where the hell is the SRS computer located?
Old 09-17-2014, 07:33 PM   #5
SRS computer location
The computer is located in the center console. .. at the very bottom. I've got a 1st gen taco... the computer is located behind the area where the two lower 12v outlets are. There's 4 snap in plastic bolts that you'll have to pop out. I also removed the ashtray to take out the screw behind it. (I'm attaching pics to help)
Just remember to disconnect your battery before messing with the computer. You should find a small box with 3 yellow plastic encased wires. Those are the ones you'll have to check and see if there's a short or disconnect.... again, for me it was solved by wiggling them to make sure the connection was tight.
airbag light....-img_20140819_101430-nopm-.jpg   airbag light....-2014-09-17-22.24.10.jpg
Old 09-28-2014, 04:40 PM   #6
I checked all connections but still had the light. Ordered new clock spring and the damn thing is still on. I guess I will have to take it to the dealer. Does anyone know about the drivers side seatbelt retractor? I hate to pay to get this thing diagnosed...the Toyota dealer here blows.
Old 09-29-2014, 09:23 AM   #7
Moosedog is on a distinguished road
Moosedog's Avatar
Moosedog's Tacoma Gallery
Did you check the condition of the passenger airbag on/off switch? Mine was broke from having a CD player installed. Also, check the FSM for the procedure for running SRS codes.
Old 09-29-2014, 10:54 AM   #8
I don't have the on/off for passenger side. Just plastic square piece
Old 09-29-2014, 10:57 AM   #9
EdFlecko is on a distinguished road
EdFlecko's Avatar
EdFlecko's Tacoma Gallery
This might help?
https://www.youtube.com/watch?v=Mvhl...OefhLdkQRBHuig
Ed
Airbag light,check engine, light on shifter stuck saltidadyo 2nd Gen. Tacomas 7 09-12-2014 09:10 PM
Electrical issues; key fob, traction control, airbag light, emergency brake light on Li0nel1234 2nd Gen. Tacomas 11 03-20-2014 07:54 PM
Airbag Light on, dealership says its the center airbag ECU cgutierr 2nd Gen. Tacomas 3 07-01-2013 08:11 PM
Airbag Light and DSC Light on after trying to install aftermarket airfilter MrKyfosh 2nd Gen. Tacomas 1 11-21-2012 03:01 PM
Airbag light + Airbag OFF = Frustrated JMan551 2nd Gen. Tacomas 4 09-23-2010 10:24 PM
