Remote and key in one single unit FCC BAB237131-056
Discussion in '1st Gen. Tacomas (1995-2004)' started by neneago, Oct 4, 2014.
  1. Nov 16, 2014 at 2:07 PM
    #81
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Agree, but as this is a first gen discussion forum, somebody might see the thread, think "that has nothing to do with me and I can't help them" so just glance past it.
    If it's in the marketplace, they'll say "hey, I can buy a key with remote built in...awesome"
  2. Nov 16, 2014 at 4:27 PM
    #82
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Id buy three total if I could.....
  3. Nov 16, 2014 at 8:58 PM
    #83
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Now you can, $120 later they'll ship
    #83
  4. Nov 17, 2014 at 1:59 PM
    #84
    archer401
    archer401 New Member
    Just wanted to share my great experience with neneago...just bought my used 2013 last week and it only came with 1 key and fob. I thought the dealer prices were a total ripoff considering the antiquated look of the OEM key, so I started searching for a better solution...I discovered this thread and tacomaworld...
    Ordered all in one remote key last Wednesday on ovnisf.com. neneago shipped it the same day and it made it from CA to RI and was in my mailbox on Saturday. Insanely fast and efficient shipping for free! I went into the dealer and had the key cut and the chip programmed today for $45. The service rep told me that the fob buttons would not work with my truck and gave me the programming sequence he had been trying.
    Came home and tried using the sequence below that I found on TW and it worked first try!
    Overall, very easy procedure, neneago is selling a quality product for dirt cheap! Nicer than OEM for much less.
    Here's the procedure I followed that worked on my 2013:
    1. Unlock and open the driver's door; keep the rest of the doors closed
    2. Insert key in the ignition and pull it out twice within five seconds
    3. Close and open driver's door twice within ten seconds
    4. Insert key in the ignition and remove
    5. Close and open driver's door twice within ten seconds
    6. Insert key in ignition and close door
    NOTE: Some cars required to close the door first, and then insert the key in the ignition
    7. Turn ignition from lock to ON and back once (P.Mode)...
    8. Remove key from ignition
    NOTE: The door locks should lock and unlock automatically to indicate is in programming mode
    9. Press lock & Unlock buttons at the same time for two to three seconds
    10 Press the lock button
    You are done!
  5. Nov 17, 2014 at 3:50 PM
    #85
    neneago
    neneago [OP] Well-Known Member
    Sugar Land, Texas
    Thanks! Chip programmed?? $45 to cut your key as no chip in your key. Total rip off.
  6. Nov 17, 2014 at 5:22 PM
    #86
    archer401
    The $45 was cut and chip programmed.
  7. Nov 17, 2014 at 6:00 PM
    #87
    neneago
    Sugar Land, Texas
    I just checked my orders to RI. Your in the wrong thread! lol!!! Thats why you confused me. This thread is for 1st gen Tacomas that use a different frequency and NO transponder chip.
  8. Nov 18, 2014 at 7:20 PM
    #88
    Norton
    Norton Senior Member
    Steve
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    My key arrived via USPS yesterday, 17 Nov, after having been ordered on Sunday, 15 Nov. :D
    It took only about 5 minutes to program, following the instructions in this thread. :cool:
    The local dealer took about 20+ minutes to cut it and charged me $20 for doing so. (Inexplicably pricey compared to the entire new key, including cut, I got from them a few months ago for about $15.) :rolleyes:
    It works perfectly. Thanks, neneago! :cheers:
  9. Nov 21, 2014 at 5:22 PM
    #89
    Darryle
    Darryle
    Weatherford, Texas
    It worked like a charm for me using these instructions:
    1. Start with the key out of the ignition, drivers door is open all others closed and
    drivers door is unlocked.
    2. Perform these steps within 5 seconds.
    A. Insert the key into the ignition(Do NOT Turn) Pull key out.
    B. Insert the key into the ignition(Do NOT Turn) Pull key out.
    3. Perform these steps within 40 seconds.
    A. Close then open the drivers door.
    B. Close then open the drivers door.
    C. Insert the key into the ignition(Do NOT Turn) Pull key out.
    4. Perform these steps within 40 seconds.
    C. Insert the key into ignition and leave it in ignition.
    D. Close the drivers door.
    E. Turn the ignition to ON (Do NOT Start) then back to OFF.
    F. Remove the key from the ignition.
    5. Within 3 seconds, the power door locks should lock then unlock automatically
    indicating successful entry into programming mode.
    Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds.
    A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
    B. Immediately after letting go of the lock and unlock buttons,
    Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
    locks should lock and then unlock once indicating successful programming. If
    the door locks cycle twice, repeat steps A and B in step 6 as the remote was
    not accepted.
    C. Repeat steps A and B in step 6 for each new remote.
    7. Open drivers door.
    I tried twice with the ones listed here and it never took, worked on the first try with the instructions I listed above.
  10. Nov 21, 2014 at 5:55 PM
    #90
    neneago
    Sugar Land, Texas
    Same steps I posted, just worded a bit different. Step 6..B.. might be different in some vehicles. I have noticed that after releasing lock/unlock, some cars will accept remote with unlock, lock or unlock/lock. Very strange. This I only noticed with the remotes I sell. OEM is always Lock after the initial lock/unlock.
  11. Nov 22, 2014 at 8:12 AM
    #91
    Darryle
    Darryle
    Weatherford, Texas
    It wouldn't work with my 2004 using unlock, but worked perfectly with lock.
  12. Nov 27, 2014 at 5:40 PM
    #92
    pittim
    Pennsyltucky
    Boujee Prius
    Just ordered one
  13. Nov 28, 2014 at 5:29 PM
    #93
    neneago
    Sugar Land, Texas
    Here are pictures of the cheaper shells and the newly engineered(no logo) shells I have.
    Right is new design
    Left is new designed buttons
    http://youtu.be/_8ZnapSvVfo
  14. Nov 30, 2014 at 8:59 AM
    #94
    04toco
    04toco Active Member
    Sean
    Charleston, SC
    04 PreRunner TRD Doublecab
    Dual flowmaster exhaust, tinted windows, 3 inch lift, kobalt tool box, Westin light bar, satoshi grill, painted parts everywhere K&N intake
    The number on the back of my key is FCC D:BAB237121-056. How do I know which key on the website to get? I assume it's on of the first two on there. Thanks
  15. Nov 30, 2014 at 9:05 AM
    #95
    04toco
    Sean
    Charleston, SC
    Nevermind. Should have took the time to look at the one on the very bottom :rofl:
  16. Dec 6, 2014 at 7:58 PM
    #96
    04toco
    Sean
    Charleston, SC
    My key came today!! It was very easy to program if you follow the instructions right. Took it to lowes and they cut it for me for no charge since they didn't have anything to charge me for! Worked perfectly. This is honestly probably the best purchase I've made for my truck so far (besides my lift, sorry :p ). But seriously I would recommend this to anyone. Great quality key. Good work neneagro. Make some stickers for your key and I'll be your first sponsor :D
  17. Dec 11, 2014 at 5:26 PM
    #97
    neneago
    Sugar Land, Texas
    15% off Coupon. Will only work for the first 10 people who use it.
    "tacoma" is the coupon without the quotes.
  18. Dec 11, 2014 at 5:47 PM
    #98
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Thanks. I just bought a couple of keys for my 2002 Tacoma.
  19. Dec 12, 2014 at 3:44 PM
    #99
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    any chance these would work with an aftermarket keyless (viper) entry?
  20. Dec 12, 2014 at 5:14 PM
    #100
    neneago
    Sugar Land, Texas
    It will not work.
