Wipers not working
Old 11-19-2014, 07:56 PM   #1
Parsec [OP] Parsec is offline
Parsec is on a distinguished road
Parsec's Tacoma Gallery
Question Wipers not working
So my wipers aren't working. Any suggestion?
Old 11-19-2014, 07:59 PM   #2
Artruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shedArtruck is one of the sharper tools in the shed
Artruck's Avatar
Artruck's Tacoma Gallery
Check fuses....
Does your washer fluid still work?
Old 11-19-2014, 08:17 PM   #3
No the fluids don't work and I changed the fuses.
Old 11-20-2014, 08:03 PM   #4
keakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shed
keakar's Tacoma Gallery
first the fluid might be empty so refill the reservoir and recheck.
second check your fuses again with a test meter and not just by looking at them and also check the fuses under the hood.
if the fuses are all good and you are sure it has power going to it and the wipers don't even try to work then im thinking you wiper module has lost power from a blown fuse or it has gone bad which is unlikely the water fluid pump to go bad too but you need to test it to be sure. see if the washer fluid pump and the wiper motor is getting power, if not then the problem is probably in the steering wheel wiper arm module.
Intermittent speed not working on wipers Dtaw New Members 0 09-18-2014 03:13 PM
Wipers Not Working farbio615 2nd Gen. Tacomas 7 12-20-2011 11:09 AM
Intermittent Wipers not Working jchristian11 1st Gen. Tacomas 1 03-20-2011 03:38 AM
Windshield wipers not working... cadman Technical Chat 3 01-16-2010 03:06 PM
Wipers stopped working Tejas TJ 1st Gen. Tacomas 3 10-19-2009 10:19 AM
