4X4 Won't disengage
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03BLACKBEAUTY, Nov 23, 2014.
  1. Nov 23, 2014 at 5:14 PM
    03BLACKBEAUTY
    03BLACKBEAUTY [OP] Member
    Hi i am new to the Toyota world i just bought a 95 toyota tacoma ext cab with the v6 and standard transmission my issue and only issue with the truck is when u pull the 4x4 lever it goes into 4x4 everything works great but when i take the lever out of 4x4 and put it into 2wd the truck stays in 4x4 like i said i am new to the toyota world and i appoligize about lenghty thread thanks
  2. Nov 23, 2014 at 5:17 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    Just keep rolling slowly without turning the steering wheel and it should pop-out of 4WD. Try backing up as well. The key is to relax any stress on the driveline. I presume you are on dirt or snow, and NOT using it on DRY pavement?
  3. Nov 24, 2014 at 2:56 AM
    03BLACKBEAUTY
    Yes i am on dirt i will give that a try thank you
  4. Nov 24, 2014 at 6:31 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This, sometimes it takes a few seconds to disengage. You have a fully mechanical transfer case so there's no reason it shouldn't be disengaging unless there is something wrong internally.
