Auto transmission rattle when in Drive / Stopped
Old 11-30-2014, 12:26 PM   #1
scott72 [OP] scott72 is offline
scott72 is on a distinguished road
scott72's Tacoma Gallery
Question Auto transmission rattle when in Drive / Stopped
Hi all,
Anyone seen a automatic transmission make a rattling noise when in Drive, and
stopped at a stoplight?
My '97 started doing this a few months ago. The rattling goes away as soon as I let off the brake and start moving, or shift into park or neutral. Any ideas?
And yes the fluid level is fine. =)
Old 11-30-2014, 06:05 PM   #2
gearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shedgearcruncher is one of the sharper tools in the shed
gearcruncher's Avatar
Firefighter: training officer
Name: Canadain bumber technician
gearcruncher's Tacoma Gallery
What happens when you are in reverse and stopped with the engine running ? do you get the same rattle you hear when you are in drive or is there no ratlle at all ?
Are we working with a 4x4 or 2 wheel drive ? what size motor ? Got a lift kit ?
Old 12-01-2014, 07:06 AM   #3
In reverse the noise goes away as well when running and stopped with brakes on.
4wd 2.7 L no lift kit
Old 12-01-2014, 01:23 PM   #4
Mas Tequila!!!
JuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shedJuansTaco is one of the sharper tools in the shed
JuansTaco's Avatar
JuansTaco's Tacoma Gallery
mine is doing this at the moment. but mine is from the motor mounts not being bolted up.
a while back they did the same thing but the ears on the perches broke off so it was free and vibrating
Old 12-04-2014, 08:36 AM   #5
Judging by your explanation , I would be looking at the transmission mount and motor mounts. Go under the truck with a pry bar and pry away . Something is loose or worn out
Old 12-04-2014, 09:11 AM   #6
Thanks for the tip, I will check this out.
Old 12-04-2014, 09:58 AM   #7
Mas Tequila!!!
JuansTaco's Avatar
Here is what a bad motor mount looks like.
Also the ears may have broken off so it will look like it's not seated properly
Old 12-04-2014, 11:52 AM   #8
keakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shedkeakar is one of the sharper tools in the shed
keakar's Tacoma Gallery
if you look under the tranny support there is a little doo-hicky (technical term) that looks like a leg under a refrigerator and its there to prevent the bracket from falling off the tranny or something (cant remember what the Toyota guy told me it was for) but on mine it was loose and rattling so I went under there and put a zip tie on it and boom no more rattle and quiet as a mouse.
you will see what im talking about when you get under there.
I almost cut it off but someone told me its there for a reason so I left it.
Old 12-05-2014, 05:19 PM   #9
Here are the shots, doesn't look like the mounts are bad.
Hard to get under there to see what is rattling, by the time I get back to my garage it stops. Doesn't do it every time.
Plus i have to get my wife to hold the brake in drive while I am underneath.....
Auto transmission rattle when in Drive / Stopped-dsc03427.jpg   Auto transmission rattle when in Drive / Stopped-dsc03429.jpg   Auto transmission rattle when in Drive / Stopped-dsc03430.jpg
Old 12-05-2014, 07:12 PM   #10
JasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shedJasonLee is one of the sharper tools in the shed
JasonLee's Avatar
JasonLee's Tacoma Gallery
I had the same symptoms when I bought my truck. I ended up having to have the transmission rebuilt for over $2k. I hope your problem isn't this severe.
Old 12-06-2014, 02:51 AM   #11
Mounts look OK visually but you have to pry at them to tell if they are starting to fail . Maybe take it to a shop where they can put it up on a hoist and look, this way you can have someone sitting in the truck moving the transmission through the gears as you try and reproduce the rattle
Old 12-07-2014, 02:27 PM   #12
Well I finally found out where the rattle was coming from. Started rattling as I was pulling out of my garage so I had time to look for it with some help.
It looks like a bracket holding up the back of my cat converter, vibrating against the exhaust pipe.
Luckily it is not my tranny!
Thanks for the help all.
Auto transmission rattle when in Drive / Stopped-dsc03432.jpg
Old 12-08-2014, 09:22 AM   #14
wow, what a stupid design that is
glad mine isn't anything like that, must be a 4wd or prerunner thing
Old 12-09-2014, 07:15 PM   #15
Yeah I was thinking the same thing. I don't know why it just started rattling either. Doesn't look like anywhere to tighten it, it is held on by two rubber pieces unless they are starting to wear out and causing more play.
engine revs while stopped in drive Freki 1st Gen. Tacomas 5 05-01-2014 03:38 PM
Truck shakes while stopped (Drive/Auto tranny) 1flossedTRD 1st Gen. Tacomas 12 09-09-2013 08:01 AM
Driveshaft noisy while stopped in Drive. Jbone11 11 2nd Gen. Tacomas 3 08-08-2013 10:51 AM
Auto Off stopped working. Brunes Lighting 2 12-30-2012 07:44 PM
tranny making noise in drive while stopped mackattack07 1st Gen. Tacomas 4 06-06-2012 05:22 PM
