04 Taco - Engine Coolant Temp. Sensor?
Old 04-27-2009, 04:00 PM   #1
gunn [OP] gunn is offline
gunn is on a distinguished road
gunn's Tacoma Gallery
Hey guys,
New to the forums and looking for some advice on this issue.
I just bought a used 2004 Tacoma with 55k miles. It's the V6 4x4 extended cab. Loving it! Although I already cracked my windshield
I didn't get the extended warranty (hmm, wondering now) from the dealer so it's out of warranty. One thing I didn't notice while looking and driving it at the dealer was that the engine temperature gauge doesn't work. Here's what I've found:
-When I start the car up in the mornings (it's still in the 20s here in Durango at night) the gauge automatically jumps up to the midpoint. It spends no time at all on cold.
-While driving the car the gauge never moves from this midpoint position.
-The heater works fine as it should. The truck idles fine and nothing else indicates that there is an issue. The check engine light has not come on.
So, my original thought was that the ECT sensor is faulty but I would expect the check engine light to come on if this was the case. Is there a fuse somewhere that sits between the sensor and the gauge?
Has anyone seen this happen to your Tacoma? What do you think is going on? I'd like to fix this one myself and avoid the shop.
Thanks!
Old 04-27-2009, 04:17 PM   #2
bobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shedbobwilson1977 is one of the sharper tools in the shed
bobwilson1977's Avatar
bobwilson1977's Tacoma Gallery
That is definitely weird. When you say it jumps to the mid range, do you mean it does it as soon as you turn the truck on, or after its been running a little bit? When the truck has warmed up, is the radiator hot to the touch? That would be my first order of business because one other reason the temp gauge could jump up is if there's some sort of blockage.
But I'd at least put the truck on a scanner and see what comes up. Its possible that whoever sold it to you reset the computer and erased the codes.
Old 04-27-2009, 04:31 PM   #3
As soon as I turn the truck on/crank it over it goes to the middle (actually just above the midline). This is after sitting in the cold all night.
I'll check it with a scanner and see what it pulls up and let you know. Thx!
Old 04-27-2009, 04:33 PM   #4
I think you might be right then. It sounds more electrical than mechanical.
Old 04-27-2009, 05:38 PM   #5
OK, pulled the codes at Autozone--"No codes found". I'm thinking it might be the sending unit but I'm not sure.
Old 04-27-2009, 05:53 PM   #6
EnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shed
EnolaGaia's Tacoma Gallery
No, there's no fuse between the temperature sender and the gauge in the cluster.
Failure in the coolant temperature gauge or circuit would not / does not trip a CEL of any kind.
Either the sender or the cluster temp gauge is messed up. There's an outside chance it could be a wiring fault (e.g., bad ground).
Old 05-02-2009, 08:24 PM   #7
Well, finally taking a look at this again and I've decided to replace the sending unit ($15) and see if it improves. It's a royal pain in the ass to get to but so far I have:
1) Removed timing belt cover bolts
2) Instead of draining the coolant I have slid the upper radiator hose clamp down the hose (zip tied it to keep pressure off the hose) and slid the timing belt cover down. Hopefully I won't lose too much coolant when I remove the sending unit.
3) Loosened one bolt on the fuel pipe and it was getting dark so I came inside after trying to get the second bolt loose. I think this second bolt is going to be a pain to get off.
See: http://ncttora.com/fsm/2003/Repair_M.../ects/insp.pdf
Anyway, nothing simple in the world of vehicle wrenching! For now, it's better than paying for such a simple problem...I'll let you all know tomorrow if replacing the sender fixes the problem.
Oh, the service manual says that the gaskets on the fuel pipe should be replaced. Isn't that kind of overkill?
Coolant Temp dann 190 1st Gen. Tacomas 6 03-28-2011 08:34 PM
coolant temperature sensor DaytonLax14 Technical Chat 6 09-30-2010 09:01 PM
Coolant temp sensor location lncgnzls100 2nd Gen. Tacomas 1 07-03-2010 11:10 PM
help with coolant temp sensor please nayber 1st Gen. Tacomas 1 04-25-2009 12:58 PM
3.4 coil packs, rear O2 sensor, water temp sensor glassdoc Buy / Sell / Trade 6 01-28-2009 07:51 AM
