Transmission Identification Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by cummins4408, Apr 29, 2009.
  1. Apr 29, 2009 at 12:33 PM
    cummins4408
    cummins4408 [OP] New Member
    Hey guys, I'm new on here and am in desperate need of a Identification code for the transmission that's in a 2003 extended cab 4x4 5-speed with the 2.7 liter 4 cylinder. Any leads on rebuild kits/shops, etc. would be great. I believe its the syncros but not sure. It will only go into fourth gear when its RPM matched before shifting. Where's the cheapest place to get a clutch also.
    Thanks,
    Rodney
  2. Apr 29, 2009 at 2:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!!!
    The tranny you have is the W59. Not sure where to get a rebuild kit from...
  3. Apr 29, 2009 at 7:18 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    There is also the information sticker located on the inside of the drivers side door jamb
    In my case it's the A340F
    REDdawn6 likes this.
