ABS light blinks rapidly... no scanguage or ultraguage
Discussion in '1st Gen. Tacomas (1995-2004)' started by ImpulsedComa, Dec 31, 2014.
  1. Dec 31, 2014 at 10:46 AM
    ImpulsedComa
    ImpulsedComa [OP] Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    The past 2 mornings on my way to work (very cold out), my abs light would blink very fast as the truck was warming up, I would start to drive and it continued, it would stop for a while, then blink really fast again. The trucks brakes were not effected. My commute isn't more than 10 minutes but it continued that cycle the whole way.
    On my commute home in the evening, everything was normal (no flashing). Back and fourth from home to the gym after work, everything was normal also.
    Brake fluid is at the full mark and i had a friend put the truck on a lift to physically inspect the brake sensors and they seemed ok also.
    I searched and only found people having this problem who have ultrguage or scanguages. I don't have any of those. The only thing that has changed recently was the professional installation of an avital 4103 remote starter, but that was a couple weeks ago and this just started happening 2 mornings ago.
    Any ideas? thanks
  2. Dec 31, 2014 at 10:47 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    anything in your obd port?
  3. Dec 31, 2014 at 11:04 AM
    ImpulsedComa
    NJ
    sorry, nothing in the obd port either.
  4. Jan 1, 2015 at 9:00 AM
    ImpulsedComa
    NJ
    So this morning i remote started the truck for about 10 minutes, went outside and the abs light was not blinking. Drove to work and the light never started to blink. Not complaining, just find it weird that it stopped... Not sure whats going on.
  5. Jan 1, 2015 at 9:55 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Possibly moisture found its way on to the reluctor rings of the abs system? What was the weather like other than cold? Moist/Damp drive home the night prior to problem starting?
  6. Jan 1, 2015 at 10:01 AM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Check your under hood wiring at the ABS module and where it goes along with inner fender. I've seen mice/rats chew on the wires in this area. Otherwise check the wiring under the dash at the OBD2 port for any tampering.
  7. Jan 1, 2015 at 12:37 PM
    ImpulsedComa
    NJ
    past three nights were just cold, probably around 35. No differences in them come to mind... The two morning were when it happened were maybe a little colder than this morning but nothing crazy different.
  8. Jan 1, 2015 at 12:40 PM
    ImpulsedComa
    NJ
    Thanks, I checked under there and found nothing out of the ordinary. I have off the next few days so i wont be starting the truck so early in the morning, so im guessing it wont happen for the next couple days.
  9. Jan 1, 2015 at 2:37 PM
    LegitGreenTaco
    LegitGreenTaco Photosynthesis.
    2002 Regular cab base A/C fixed now.
    Westin lights, Westin Light bar holder, New front bumper, Custom floor matts, Steering wheel cover, board in bed to keep groceries from rolling around, new radio, New flat bed cover.
    Just keep a close eye on it and check the OBD port and if it blinks again...i dont know what to do
  10. Jan 1, 2015 at 3:13 PM
    ImpulsedComa
    NJ
    ok cool, thanks
  11. Nov 13, 2019 at 8:10 AM
    Muscrat
    Muscrat Member
    2002 TRD
    ImpulsedComa, did you ever figure this out? I am having this same issue on my 2002.
  12. Nov 14, 2019 at 9:09 AM
    ImpulsedComa
    NJ
    have since sold the truck, but it was happening in the cold and stopped when the truck warmed up...
    Muscrat[QUOTED] likes this.
  13. Nov 14, 2019 at 9:16 AM
    Muscrat
    Muscrat Member
    2002 TRD
    Thanks for getting back to me. That's exactly whats happening. I guess I'll just live with it.
    Thank you!
  14. Nov 14, 2019 at 9:34 AM
    ImpulsedComa
    NJ
    prolly just water in a sensor that freezes and warms up
