how high
Discussion in '1st Gen. Tacomas (1995-2004)' started by mightytaco007, Jan 23, 2015.
  1. Jan 23, 2015 at 7:23 AM
    mightytaco007
    mightytaco007 [OP] Active Member
    Laveen
    04 trd tacoma
    3in fabtech dirtlogic lift with 33s
    How high can i go before ill have to get a full lift kit on my Tacoma. i have fab tech 2.5 shocks to 3in and a 3/4 in diff drop but i want to go another inch to keep my tires rubbing. Can i put a 1in spacer to get my inch would that affect my CV axles or would i have to drop the diff more?
  2. Jan 23, 2015 at 7:27 AM
    mightytaco007
    Laveen
    04 trd tacoma
    So anymore then 3 ill have to get a lift kit?
  3. Jan 23, 2015 at 7:31 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    if wheel rubbing is your main concern, would wheel spacers solve your issue?
  4. Jan 23, 2015 at 7:33 AM
    mightytaco007
    Laveen
    04 trd tacoma
    It probably could but they dont seem they would be to sturdy when i'm flying through the desert. I've heard they can rip the tire off when you hit a bump real hard.
  5. Jan 23, 2015 at 7:34 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    depends.
    how small?
  6. Jan 23, 2015 at 7:35 AM
    jlm22
    jlm22 New Member
    Espanola New Mexico
    06 SR5 4x4
    6-in Fabtech lift, K&N Cold Air Intake, TRD Exhaust,
    After 3'' in the front you will need to get a lift kit, yota243 makes a good point wheel spacers may help or cutting an angle to the inside of the wheel-well may help also depending on where you are rubbing.
  7. Jan 23, 2015 at 7:37 AM
    mightytaco007
    Laveen
    04 trd tacoma
    Im rubbing on the inside of the fender well by the cab its moslty when im flexing on a turn or when i hit a bump fast. How much would i need for a spacer that will be strong?
  8. Jan 23, 2015 at 7:38 AM
    yota243
    E.J.
    north Alabama
    wheel spacers should be the same as having less backspacing (i think less would be the term i need to use there if not then more) you could also do a 1" body lift to clear your tires. theres no really great solution but i would think those two would be ok fixes.
  9. Jan 23, 2015 at 7:41 AM
    mightytaco007
    Laveen
    04 trd tacoma
    I think ill go with the wheel spacers maybe a inch should be could.
  10. Jan 23, 2015 at 7:56 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Pictures of where you are rubbing would be very helpful in solving your dilemma.
    If you haven't done so, you want to beat down the pinch weld.
    Wheel spacers increase your scrub angle and may not solve the problem (pictures would help) as you may still be contacting the wheel well after install.
    A 1" body lift may help more. It depends on where you are rubbing (pictures would help). Several folks are running with good results. The 2" and higher body lifts are not recommended because they get more involved with the couplings between body and frame as well as creating a larger lever arm on which the cab is mounted on (increasing sheer forces on the cab mount bolts).
    I'm not exactly sure what you mean by "a full lift kit".
  11. Jan 23, 2015 at 8:15 AM
    mightytaco007
    Laveen
    04 trd tacoma
    It is rubbing on the pinch weld. I have beaten it down some but i think i need to more. For a body lift what would you recommend? Like a Rough Country or a Fabtech lift for a 6in. i'm not good a explaining things like that.
  12. Jan 23, 2015 at 8:18 AM
    mightytaco007
    Laveen
    04 trd tacoma
    Thats what there called?
    would that be the way to go for a 4in thats how high i want to go
  13. Jan 23, 2015 at 8:35 AM
    mightytaco007
    Laveen
    04 trd tacoma
    If i changed the upper control arm would that give me more travel? I looked they don't for first gens i think ill look in to more a body lift and see if i can do that if i cant ill probably bang that pinch weld to flat
  14. Jan 23, 2015 at 9:29 AM
    tomtom
    The Desert SW
    2012 FJ
    The uniball design UCAs allow for more travel. I've heard the ball joint on the Light Racing UCAs have more articulation than stock so they would as well. However, I'm not sure how this would solve your rubbing issue.
  15. Jan 23, 2015 at 9:37 AM
    tomtom
    The Desert SW
    2012 FJ
    Also, OP, have you had an alignment done to see if the caster can be changed to help?
  16. Jan 23, 2015 at 5:35 PM
    mightytaco007
    Laveen
    04 trd tacoma
    The uppers wont help but ive been wanting to change them to help with my articulation and curious about it.
