'03 Tacoma with 3" Lift having trouble finding replacement rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Paultra, Feb 20, 2015.
  1. Feb 20, 2015 at 2:36 PM
    Paultra
    Paultra [OP] New Member
    Paul
    Tacoma
    3" Lift
    '03 Tacoma with 3" Lift having trouble finding replacement shocks. Can someone help me out please?
  2. Feb 20, 2015 at 2:38 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    More details.
  3. Feb 20, 2015 at 2:47 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ok: Good: Better: Best: Edit: These are rears only... the first time i read ur post i thought it said rear.
  4. Feb 23, 2015 at 8:54 AM
    Paultra
    Paul
    Tacoma
    3" Lift
    Thanx Styx, but I need to confirm. Firstly, yes, I was looking for rear shocks only.
    The Bilstein 5100 was my first choice, but I saw conflicting information on-line. Some sites clearly stated they have just one inch of travel, but other sites include those in 3" lift kits, so I called directly to the Bilstein Distributor in Canada (Essex) and was told they are only good for 0-1" lift. Yet another call to different person at Essex said they would work in a 3" lift, but the first person disagreed saying I would pull them apart in no time. So, even at the distribution level there are two different opinions.
    It looks like you have the same Tacoma, so you know the left & right rear shocks are different lengths, so it's a bit unusual. I measured the total length of each existing shock, and got 19.5" for the left, and 21.5" for the right, so about 18" & 20" center to center, and this is slightly compressed with a couple of hundred pounds of box weight. I plan to remove the weight today and re-measure (really nice weather in Calgary right now, so I can drive without it).
    What do you think, will the Bilstein 5100's be OK?
  5. Feb 23, 2015 at 9:26 AM
    Brake Weight
    Get your static load measurements of the shock lengths. Take this and compare to the lengths of the 5100 shock. If it's acceptable, go for it. I, personally, run a set of 5125 rears for a T100. They're slightly longer and work perfect for my ride height.
  6. Feb 23, 2015 at 9:36 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    I can't tell you from personal experience if the 5100's will work with 3" of lift, as I am running the Icons with only 1.5" of lift... but i'm pretty sure there are a ton of guys on TW running 5100's with 3". It's pretty easy to unbolt the rear shocks and take measurements. Then you should be able to find the collapsed and extended measurements of 5100's to compare.
    Edit: BTW OP what leaf setup are you running in the rear to get 3"?
  7. Feb 23, 2015 at 9:47 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Jason
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Just call or email and then buy what you need from them because they will give you the correct answer immediately instead of people on here offering you many different opinions.
  8. Feb 23, 2015 at 11:52 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^^x2^^^
