are there any hood light mods?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Mar 9, 2015.
  1. Mar 9, 2015 at 11:36 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    2006 4runner sport 4.7L V8 (white)
    used to have - 99 2.4L I4 5 lug & 04 prerunner v6
    just wanted to know if there are any mods for seeing under the hood at night?
    I know I can just put a 12v light bulb socket and switch but I was wondering what others have done that looks nice.
    I know anything I put together will look a little ugly and home made so I wondered if I could get some ideas here on what cars to look to take one off of to look OEM.
  2. Mar 9, 2015 at 4:31 PM
    keakar
    karl
    louisiana
    I saw those but im actually looking for less then that, something in a simple basic sertup like a single bulb just to see with.
    tacodayne's kits are great and its like daytime at night but that's way over the top of what I had in mind to do.
    im thinking way more basic then that like one light bulb in a socket bracket you can screw onto the hood somewhere like my old 74 cougar xr7 had, those had mercury switches in them to turn on when you raise the hood. I think they did away with them because of the mercury switch but im guessing there is still something of that same basic design still in use on some cars.
    I had been looking at these but was waiting to see if someone had better ideas http://www.ebay.com/itm/2x-White-12...Parts_Accessories&hash=item54199d3f73&vxp=mtr
  3. Mar 9, 2015 at 5:08 PM
    ThomasMore66
    ThomasMore66 We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    Supercharged 2013 TRD Offroad 4wd
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
  4. Mar 9, 2015 at 8:41 PM
    keakar
    karl
    louisiana
    what kind of lights are those?
  5. Mar 9, 2015 at 9:01 PM
    ThomasMore66
    KC cyclone. KC makes a kit, but this isn't that one. Made mine with two lights and a switch/wire from BeeRadd. He has an ongoing buy for his set-up. However, these are cool. I may add some more.
  6. Mar 9, 2015 at 9:02 PM
    ThomasMore66
  7. Mar 9, 2015 at 9:09 PM
    JohnB81
    JohnB81 Well-Known Member
    John
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
    AntiDark LED lights by BeeRad!
    Go with his pro kit, install is super easy and an overall smart set up. Also very budget friendly,... Less than a tank of gas!
    Search BeeRad AntiDark underhood lights in the search bar and check out his YouTube videos https://m.youtube.com/watch?v=P7W0XFzAQu8
  8. Mar 9, 2015 at 9:10 PM
    ThomasMore66
  9. Mar 9, 2015 at 9:16 PM
    keakar
    karl
    louisiana
    ok, I'm mainly looking for ideas on different lights and stuff maybe how they are arranged is all im in need of. I did electrical work for 35 years so I have all the wire and switches and all that already, its just the lights I am in need of.
    I certainly don't mean to poo-poo anyone doing this as a kit to help others, I applaud them doing that and it takes work to put it all together and shipping it out to people and dealing with the issuesrelated to all of that.
    that said, when buying a kit, you pay a premium for "one stop shopping" that I am not inclined to pay.
    I want to buy the lights and do it all myself and avoid paying someone to put it all in a box with a switch and some wire for me and ship it to me for a small markup.
    what they sell is totally worth it, and its obvious they don't make much money doing it, so im not implying anyone doing this asks too much, im just saying I don't need to pay someone to put a kit together for me is all.
  10. Mar 9, 2015 at 9:21 PM
    ThomasMore66
  11. Mar 9, 2015 at 9:38 PM
    keakar
    karl
    louisiana
    hmm, those led strips in BeeRad's kits looks like a great solution for the type of light I should get, but I doubt if it would stay stuck in the intense heat (110 heat index in the shade in august) we have here. anything not held down by gravity or held in place with a fixed fastener peels off so I can see I would need to use several screws and clamps every few inches to hold it from peeling off. but it is an interesting idea.
    http://www.tacomaworld.com/forum/anti-dark/305102-fs-led-whips-tail-gate-cb-mounts-etc.html
    thanks, but I already have these switches, they are the basic switches used for any car alarm systems and I sometimes hook them up as a horn alarm for battery thieves, it doesn't protect the truck but if they open the hood the alarm scares the shit out of em lol, and hopefully scares them off too.
  12. Mar 9, 2015 at 10:40 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    I just took a factory under-hood lite from an early 90's Chevy pickup. The assembly includes a switch, bulb holder (with plastic cover), a long tether (so that the bulb-holder can be located anywhere under the hood) and a crank to reel it back in. The tether is long enough to stretch over to an adjacent vehicle.
    Cost me $15 at the PnP, plus some wire, and a fuse-holder.
    See attached photo. The bulb and plastic cover is missing in the photo.
  13. Mar 10, 2015 at 3:40 AM
    ThomasMore66
    Which is why my Cyclones bolt in.
  14. Mar 10, 2015 at 3:52 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I installed these lights from Tacodane last June. They have not had any heat issues. I like the wrap around strips so I'm not casting a shadow on my work.
  15. Mar 10, 2015 at 4:36 AM
    ThomasMore66
    I agree that pattern is better. I've been contemplating added two more cyclones lower in the engine compartment.
  16. Mar 10, 2015 at 9:05 AM
    keakar
    karl
    louisiana
    I think I found the perfect alternative, these are strips but on an aluminum rail that screws on securely so there is no worries about stuff held with tape and I get full coverage. picture shows 2 but the price is just for one and its 19 1/2" long.
    http://www.amazon.com/white-Aluminu...6&sr=1-33&keywords=Pure+White+LED+Strip+light
    I figure 2 of these in pure white color across the top or 3 of these with one the top and one on each side outta do the job nicely and at $5 each they are at the price I wanted them to be in.
  17. Mar 10, 2015 at 11:53 AM
    ThomasMore66
    Clearly they're cheap!
  18. Mar 10, 2015 at 1:41 PM
    keakar
    karl
    louisiana
    thats what worries me lol, ya never know the quality of em or how long they will last but the idea of the rigid strip sounds better then anything that is tapped on with double sided tape
