Wheel these TRD FJ cruiser wheels fit my truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Saucy, Mar 17, 2015.
  1. Mar 17, 2015 at 11:46 PM
    Saucy
    Saucy [OP] Well-Known Member
    Nor-Cal
    1997 taco & 2019 tacoma TRD Off-Road
    Too many to list
    Hello, I have a 97 toyota tacoma and I want to get these wheels (if they will fit) http://www.ebay.com/itm/16-Toyota-F..._Car_Truck_Wheels&hash=item4d2c469348&vxp=mtr
    Anyway I apologize if this question has already been asked. Ebay says it will NOT fit but I don't know why...Everything looks right to me except these are 15mm offset, (really don't know what that means or if that even matters) Also these are 16" wheels and the stock rims for my truck are 15" (I'm 99% sure) HOWEVER, I have Fabtech suspension on my truck so it sits at least an inch or more higher then stock...Anyway any info you guys have about why they will or will not work would be greatly appreciated. ANY PICTURES OF THESE WHEELS ON MY MODEL YEAR TRUCK WOULD BE AWESOME. and will the tires rub with these wheels on my truck (if they will I'm not doing it) THANK YOU
  2. Mar 18, 2015 at 4:39 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    The key is not the offset, I don't understand why everyone keeps referencing that. The key is the backspacing, the backspacing on stock 15's is 4.5 inches so if those FJ 16's have the same backspacing and you don't use too fat a tire they should fit just fine.
  3. Mar 18, 2015 at 5:06 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Yes. They will fit. No issues or concerns to be had
    Here's a tool for wheel/tire fitment
    http://www.rimsntires.com/specspro.jsp
    However, offset does indeed matter just as much a backspacing when selecting wheels. By playing around with the tool you will realize what the terms mean and how it can effect your fitment.
  4. Mar 18, 2015 at 9:02 PM
    SVCTECH7
    SVCTECH7 Member
    Florida
    10 SR5 DLB CAB 4x4
    Husky Floor Liners Stubby Antenna Fog Light Mod ARE X-Series Topper w/Tool box sides Yakima Roof Rack OME 3' lift with HD spring package Bed slide Wet Okole seat covers
    They should, I just put a new set of wheels at a shop that installed the same set as mine on an FJ a few hours earlier.
  5. Mar 18, 2015 at 9:37 PM
    Saucy
    Nor-Cal
    Too many to list
    AWWW those wheels look awesome...i was almost gonna buy those ones instead...Do you know the exact size of those? I'm a little worried because the ones i bought say they are 16X8...But everyone else that had them for sale on ebay has them listed as 16X7.5
    Oh and what are the tires and size on those? My truck is 1st gen though 97 tacoma, hopefully the wheels i bought fit and don't rub cuz I'm not getting spacers so if they don't fit without rubbing They will be for sale.
  6. Mar 18, 2015 at 9:42 PM
    Saucy
    Nor-Cal
    Too many to list
    Oh and one more thing i forgot to ask, whats the backspacing on the wheels you got? I'm sure they are probably the same as the ones i did since they are both TRD FJ wheels, yours are just a different style.
  7. Mar 19, 2015 at 7:19 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    Tire Rack is a good place to check out backspacing and off sets, you can usually find these numbers for OE and then see how each wheel you are looking at compares to OE.
    Many tire places will not sell you a tire that is larger or much different than stock. They say they are not allowed to, but many times they don't know what they are talking about. A larger tire will effect your handling, speedometer/odometer, and your gear ratio, it makes your gearing "taller" and adds more load on your auto transmission and clutch if manual. You will have a lower RPM at the same "real" speed as measured by GPS and radar guns.
    Risk wise, going to a different back space or offset may mean rubbing on something or if you go out too far from the base, you are adding a lot more pressure on wheel bearings causing premature failure.
    A bit off OE is nothing to worry much about.
    Don
  8. Mar 19, 2015 at 8:40 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
  9. Mar 19, 2015 at 11:27 AM
    Saucy
    Nor-Cal
    Too many to list
    Thanks for the pics----MY FINAL QUESTION IS----Will my truck need spacers because of wheel rub??? The tires I am gonna put on are either gonna be 265/75/R16 or 265/70/R16
  10. Mar 19, 2015 at 7:15 PM
    AustinDeh
    AustinDeh Well-Known Member
    Austin
    SoCal
    04 SR5 TRD 4x4
    Im running them no issues. I run 1.25" spacers just to minimize frame rub with 285/75's. Youll get a little frame rub without the spacers at full lock with the wheel compressed. and still a little bit with the spacers. Not bad though.
    Youll be fine with 265/75/R16 or 265/70/R16's.
    The looks are worth it if you go for 285/75s!
    Also mind the ebay wheels are replicas and also come with plain white hub caps. They dont have the TRD logo on them.
  11. Mar 19, 2015 at 9:25 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    I don't have any lift. Mine rub. I have 265/75 r16 and it rubbed on the frame at full turn. I got 1.25" spacers to fix it and now it rubs on the inner fender wall. I removed the mud flap and did the pinch weld mod. My tires still rub into the pinch weld area.
    It doesn't seem like a big problem, but as this is my daily driver, it drives me crazy and I will be getting some height adjustable shocks just to get it to stop. People look at me funny because it will rub just coming out of a parking lot and make a loud rubbing sound.
    Because you have some kind of lift, you may be fine. Pretty sure you'll still need spacers though...
  12. Mar 19, 2015 at 10:25 PM
    Saucy
    Nor-Cal
    Too many to list
    Thanks for all the info...I bought 1.5" spacers today...Also when i get all this stuff actually put on my truck (probably sometime later next week) I'll be sure to add pictures to this post!
  13. Mar 19, 2015 at 10:30 PM
    Saucy
    Nor-Cal
    Too many to list
    yea, i went ahead and bought 1.5" spacers today...And Just to clarify are you saying it shouldnt rub at ALL with 265/75/16s or 265/7016s?? Oh and the link i posted to ebay wasnt of the actual set i purchased because I caught the plain center caps thing later...and bought another a diff. set.
    And lastly, bad ass looking truck.
  14. Mar 19, 2015 at 10:47 PM
    paquu
    RI
    42" LED bar
    Yeah actually, could you could take a shot with a tape measure to see:
    The height from ground to top of the fender flare.
    The gap between the wheel turned and the pinch weld/mud flap bolt area.
    I'd like to know what height I'll have to adjust some shocks to to not have problems. I can compare yours to mine. No biggie if you can't. Thanks.
  15. Mar 19, 2015 at 11:21 PM
    Saucy
    Nor-Cal
    Too many to list
    Ya no problem...I'll try to take measurements for you right after i get my stuff put on...Like I said, probably will be sometime later next week.
  16. Mar 20, 2015 at 5:55 AM
    SVCTECH7
    SVCTECH7 Member
    Florida
    10 SR5 DLB CAB 4x4
    The size is
    17 inch x 7.0 inch x 4 mm offset
    The tires are BF Goodrich All Terrain T/A KO2 P275/70R17
    FYI I have a 3'' OME lift
  17. Mar 26, 2015 at 6:16 PM
    Saucy
    Nor-Cal
    Too many to list
    So i got my stuff put on today...So first off I'm friends with the guy at my local tire store and he assured me that there was no way any tire size bigger then 255/75/R16 would fit without rubbing on my setup. I ended up buying 245/75/R16s because he was 100% sure they wouldn't rub at all. So it doesn't rub at all but I might have been able to get some 255/75/16s. without it rubbing (didn't take the time to check but he said it would be dang close to rubbing) Anyway I didn't measure anything but i still can if you want me to. but either way, it sounds like if you run the same setup as me the biggest tire you can POSSIBLY run is 255/75/16 WITHOUT ANY RUBBING. Also i did end up needing the 1.5" spacers so thank you so much for warning me about that. I'll post some pictures possibly 2maro of my truck. And if you still want me to take measurements for you just let me know, I should be able to do that for you 2maro if you do. Thanks again.
  18. Mar 26, 2015 at 8:54 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yep, they fit. running 255/85 on them and they didnt rub that much.
    i did run wheel spacers to make it look a little better.
    heres what they look like used. :D
  19. Mar 28, 2015 at 7:17 PM
    Saucy
    Nor-Cal
    Too many to list
    [​IMG][​IMG][​IMG]
    'MY TRUCK' Running 245/75/R16 Cooper discoverer S/T Armor-Tek3s, with 1.5" Spidertrax spacers, and Fabtech coilovers...Other stuff i got on it includes ARB front bumper, Flowmaster exhaust, K&N cold air intake. Probably some other stuff too but can't remember. Anyway yes indeed the TRD FJ wheels will fit on a 1st gen you will need spacers though. Thanks so much for everyone that posted on this thread.
  20. Feb 20, 2019 at 3:49 PM
    Saucy
    Nor-Cal
    Too many to list
