2.5" Lift How should I go?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brutus, May 11, 2009.
  1. May 11, 2009 at 2:02 PM
    Brutus
    Brutus [OP] Well-Known Member
    Butus
    Baltimore, MD
    2012 Crew Cab Sr5 TRD 4x4
    Guys I'm looking for a small lift for my Quad Cab TRD. Posted is somewhat recent pic from the side. I've painted all the chrome since that pic. But still stock.
    I'd say 2.5" is good, 3" Max. I just bought the truck back in March. So really havent done much off roading yet, so far just sand at MD beach. Planning to get into it more, only problem is for me to wheel any where its at least 1hr drive or more. So the truck has to be useful all around. Plus I have a 6yr old son so hieght is a problem. I have side steps which he already has a little trouble with.
    My other concern is $. I've seen suggestions on here of going suspension more then spacers and blocks. Whats the big difference?
    I mean I found the Daystar 2.5" lift kit for like $160. Spacers up front, and larger shackles in the rear. Wouldnt it ride the same cause I'm keeping stock springs and leaves?
    Please anyone enlighten me... haha
    Also, I had a Cherokee few years back. after lifting it to certain point, I had to worry about the tranfer case and binding the driveshafts. Do the Tacomas have same issues? If so whats a safe lift hieght before having to go into major work? How about the CVs in the front any restriction on them? I see some have gone to Solid axles on here. I'm guessin thats only for major wheeling.
  2. May 11, 2009 at 2:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i did a small lift on my tacoma.......bout 2 inches in the front/1.5 in the rear...................i went with ome 881 coils and 5100's set at stock height..and wheelers 5 pack rear leaves in the rear. ride is great.....not too high, and getting in is easy. no diff drop needed either.
  3. May 11, 2009 at 3:42 PM
    gatorboyy13
    gatorboyy13 Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    how much was your set up all together? the lift.
