Diff locker
Old 04-14-2015, 06:19 PM   #1
Elijah [OP] Elijah is offline
Elijah is on a distinguished road
Elijah's Tacoma Gallery
Diff locker
Does the stock 2.7l have a diff lock
Old 04-14-2015, 06:29 PM   #2
I have a problem for your solution…
Snowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shed
Snowman's Avatar
Snowman's Tacoma Gallery
Very very few 2.7 manual trucks came with a locker. So general no.
If you are wondering if you have one, look for a box sticking off the rear diff housing and a "rr diff lock" button left of the steering wheel.
Old 04-14-2015, 06:32 PM   #3
There is a light switch for some kc lights that are on my front bumper that is located where the button is supposed to be
Old 04-14-2015, 06:34 PM   #4
Snowman's Avatar
I would bet my house that you dont have one. They are incredibly rare on the 2.7 and i've only seen two examples on all of the internet. (and I've seen the entire internet)
Old 04-14-2015, 06:38 PM   #5
It wasn't a rock...
Rock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shedRock Lobster is one of the sharper tools in the shed
Rock Lobster's Avatar
Rock Lobster's Tacoma Gallery
The 3rd member would look like this:
There is a noticeable actuator on the side.
Old 04-14-2015, 06:54 PM   #6
Would a stock locker off another tacoma be able to Fit my truck without doing any other mods to it
Old 04-14-2015, 06:56 PM   #7
Snowman's Avatar
Would need a new an entire rear end and new wiring for the switch. Not super easy.
Old 04-14-2015, 06:57 PM   #8
Could I make the one that's already on there lock
Old 04-14-2015, 07:00 PM   #9
Snowman's Avatar
No
But if you search here on the forum there is a ton of info on the conversion process.
Old 04-14-2015, 07:01 PM   #10
Old 04-14-2015, 07:26 PM   #11
devinzz1 will become famous soon enough
devinzz1's Tacoma Gallery
Originally Posted by Snowman View Post
No
pretty sure hes asking if he can add a locker into his stock axle. In That case yes theres many options
Old 04-14-2015, 07:39 PM   #12
It wasn't a rock...
ARB.
Old 04-14-2015, 07:45 PM   #13
Snowman's Avatar
Yes OP, an aftermarket locker can be added.
"make the one that's already on there lock" isn't super clear about adding a locker.
Old 04-14-2015, 08:24 PM   #14
Are there any automatic lockers I could put in that anyone knows of
Old 04-14-2015, 08:49 PM   #15
Detroit, spartan, aussi, lokka, powertrax lock-rite and no slip, maybe more. Ive personally got the no-slip and love it.
Old 04-14-2015, 08:50 PM   #16
Old 04-14-2015, 08:59 PM   #17
Snowman's Avatar
I have a truetrac, which isn't a "locker" per-say but I love it.
Old 04-14-2015, 08:59 PM   #18
TXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud ofTXPRO4X4 has much to be proud of
TXPRO4X4's Avatar
TXPRO4X4's Tacoma Gallery
Question
What is an automatic locker? Is that positraction like the old El Caminos used to have
Old 04-14-2015, 09:33 PM   #19
Most are "lunchbox" style lockers where there is a mechanical lock between a set of flat facing gears when a certain amount of power is applied. When not on the gas the gears are able to skip teeth allowing one wheel to spin a different speed than the other (this gives the click click click noise most have) Also the truetrac is a good option as it has good road manners and seems to transfer quite a bit of torque even when a wheel has little traction.
Old 04-14-2015, 09:38 PM   #20
Truck ~n~ Tow
TacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shed
TacoDell's Avatar
Navy: BU3....   Builder with NMCB3 1981-1986...  SeaBee's if that's easier...
TacoDell's Tacoma Gallery
^ it means it locks up when under throttle load...
and releases when there is no throttle load.
the release allows for differentiation
when maneuvering thru turns.
release commonly produces a ratcheting/clicking noise
as the vehicle goes around a sharp turn.
Occasionally it will bind or not release quickly enough
and can surprise the driver with a loud bang and chassis jerk.
Nothing is likely broken...
but occasionally it will sound as if something did !? Lol
If the road surface is oily wet...
the rig could swap ends pushing hard thru a turn...
if yer lousy at throttle control.
diff locker help please Baja1981 2nd Gen. Builds 0 02-23-2014 08:02 PM
My e-locker diff for your open diff S.B. 2nd Gen Tacoma Marketplace 56 03-30-2013 06:35 PM
What rear diff locker should i go with 06toyoboy 1st Gen. Tacomas 22 02-05-2012 02:40 AM
diff locker on 4 cyl tacomazach 4 Cylinder 28 09-01-2011 09:41 AM
Front diff locking options. e-locker, aussie-locker, lsd?) x2468 1st Gen. Tacomas 12 07-02-2011 12:18 PM
