Biggest Tire W/ 3" Lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by O-Dubs, May 22, 2009.
  1. May 22, 2009 at 1:23 PM
    O-Dubs
    O-Dubs [OP] Well-Known Member
    Hi guys i rescently became the owner of a new (to me) truck and the tires are pretty much shot, its got a 3" suspension lift on it and i was trying to fit some nice big tires n it, how big can i go without cutting any thing down?
    o-dubs
  2. May 22, 2009 at 1:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    265/75/16 or 265/70/17, depending on what size wheels you have...
    wilcam47 likes this.
  3. May 22, 2009 at 2:47 PM
    Mac2118
    Mac2118 Well-Known Member
    Pennsylvania
    01 Tacoma SR5
    odd.. I thought I was at stock height and I'm running 265/75/16's
  4. May 22, 2009 at 2:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can run that size stock...OP said with "No trimming". 33's are too big not to rub, even with a 3" lift. Its mostly the width that causes the rubbing, not so much the height.
  5. May 22, 2009 at 4:39 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    a 285/75 should be ok... its a little under a 33" and I didnt have to do much trimming, if any.
  6. May 22, 2009 at 4:40 PM
    ETaco23
    Evan
    PNW
    and Im assuming its a first gen. :)
  7. May 22, 2009 at 7:43 PM
    O-Dubs
    it is a first gen, 1996 regular cab 4x4, i would have thought atleast a 285 would fit with a 3" lift, can anybody say for sure?
    Taco Addiction likes this.
  8. May 22, 2009 at 8:33 PM
    ETaco23
    Evan
    PNW
    Yeah, me. since I have both. And I had to do verry little trimming.
  9. May 24, 2009 at 7:36 PM
    O-Dubs
    just picked it up off ebay, was so surprised to see the size, 305/70/16! and theres even room t go atleast one size bigger. They are at the wear bars and i'm in in the market for some new tires. This will be a pure off road vehicle maybe even never go on the road, maybe a couple miles but nothing to plan for. I was thinking of atleast a mud terrean but i am so intrigued by the super swampers, nothing is really holding me back, mpg doesn't matter, what do you guys think should i get some swompers, whats better for off road, really wide and tall or skinny and tall?
    o-dubs
  10. May 25, 2009 at 12:00 PM
    Showtime250
    Showtime250 Bryon
    St. Albans WV
    2003 Tacoma 2.7 4x4
    Toytec 3 inch suspension lift, Mickey T wheels, BFG MT's, weston bull bar and step bars, and aftermarket stereo
    I have an 03 with stock p265 70 r16s. I have a 3 inch suspension. I was buyin some used bfg mud terrain 33 12.50x 15s. When I put them on there was no tire rubbing at all. Tires prolly had 20k left on them. But ended up the rims rubbed the break caliber so i couldnt get them. :( Plan to order 33 12.50 by 15s here soon tho
  11. May 25, 2009 at 9:08 PM
    O-Dubs
    i just fixed my post, my truck came with 305/70/16 205 was just a typo i think that huge...
  12. May 28, 2009 at 3:46 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    It's actually a little bit over a 33" (according to BFG specs for a 285/75-16) compared to an actual 33x12.50. It's just more narrow, which helps with the rubbing problem. I'm running the 285/75-16 BFG ATs on my Tacoma with a 3" lift. I have no problems with rubbing.
  13. May 29, 2009 at 2:30 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    305/70R/16's are actually smaller then 285/75R/16's. Not by much though. The 305's are about an inch wider. Pic's in my profile of my truck w/ 305/70R/16 BFG MT's. I now have 285/75R/16 Firestone MT's on. But to answer your question I would say these 2 sizes are the biggest you could fit on a 3 inch lift without some serious trimming.
  14. Apr 22, 2017 at 7:12 PM
    SteelCity15074
    SteelCity15074 Member
    Steeler Fan
    Pittsburgh P.A.
    2010 Tacoma
    So Ktaco, would you say with my 2010 Tacoma that has a 3" lift, I can go with 285/75R/16 safely no rubbing, and it would be the biggest size..?
  15. Apr 22, 2017 at 7:46 PM
    Ktaco
    Not sure about the 2nd gen tacomas. I can only assume that you can fit them on rims with adequate backspacing with minimum trimming. Best to ask on the 2nd gen forum.
  16. Apr 22, 2017 at 8:07 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Gen 1, 2.5" lift, 265/75/16, 4.5BS. No rubbing. Depending on your BS, I would think you'd be ok.
    Prior to lift, same wheels/tires rubbed ever so slightly at full lock but barely noticeable on road. Off road a bit more.
  17. Apr 22, 2017 at 8:11 PM
    Taco Addiction
    Houston, TX
  18. Apr 22, 2017 at 8:20 PM
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    285/75r16 should be the biggest with little to no tirming, might just rub frame lock to lock, 33x12.5r15 will need tirming and pitch weld mod for sure
  19. Apr 23, 2017 at 5:00 AM
    php74
    php74 New Member
    paul
    2002 Tacoma double cab, 4wd, TRD
    Just went through this in detail. I ended up getting bfg at's 235/85 R16. I like the skinny tire look and they're a tad taller than the 265
