2000 cold starts
Old 12-06-2007, 12:34 PM   #1
blake markham is on a distinguished road
blake markham's Tacoma Gallery
2000 cold starts
Its hard to start the first then after that it start fine
Old 12-06-2007, 03:46 PM   #2
backwoodking is on a distinguished road
backwoodking's Tacoma Gallery
How hard is the start? My 2000 takes a few cranks, like 5 or so before it gets kickin. in the cold. It seems normal to me and it has never stalled.
Old 12-06-2007, 04:09 PM   #3
Carolina Alliance: Lead, follow, or get the hell outta my way
tacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shed
tacomaman06's Avatar
tacomaman06's Tacoma Gallery
how long has it been since you : 1- replaced spark plugs?
2- replaced fuel filter and cleaned throttle body?
Old 12-06-2007, 05:01 PM   #4
bite me
humanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shed
humanoid's Avatar
humanoid's Tacoma Gallery
How old is the battery? Starter? Look in to those things first. If the battery is over 4 years old then it's probably time to get a new one especially with winter knocking on the door.
Old 12-06-2007, 06:26 PM   #5
concrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shed
concrete jedi's Avatar
Army: Shit deflector
concrete jedi's Tacoma Gallery
I got nothin'
Old 12-06-2007, 07:24 PM   #6
Mean Green Machine
98yota is on a distinguished road
98yota's Avatar
98yota's Tacoma Gallery
mine does the same thing too, it takes about 4-5 times to crank b4 it starts, but i have the opposite problem. when mine gets hot and you cut it off and try to cut it back on between 10min to an hour later, it takes forever to start back up, i figured where the fuel filter sits right under the manifold and it vapor locks, but other than that idk
Old 12-07-2007, 02:01 AM   #7
I have change the plugs and the fuel filter it help a few day but now it back to the same thing.
Old 12-07-2007, 04:19 PM   #8
Sounds like fuel system has a small leak.
Old 12-08-2007, 10:44 PM   #9
Pastry Chef
tacotoe is on a distinguished road
tacotoe's Tacoma Gallery
My 01 is the same way and has been that way since new,that is it turns over longer than I think it should.I also have two GM vehicles they start almost instantly.
Old 12-09-2007, 07:36 AM   #10
Carolina Alliance Costal Div
2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of
2003greenbean's Avatar
2003greenbean's Tacoma Gallery
have the battery checked at napa of somewere like that
COLD MOTOR STARTS FARNORCAL 2nd Gen. Tacomas 11 03-01-2014 02:11 PM
Sounds like a belt squeel when it starts cold. PRBond 1st Gen. Tacomas 4 02-01-2012 03:06 PM
Cold Starts Redneck Ron 4 Cylinder 5 11-09-2011 08:20 PM
2000 prerunner starts intermitently rsta Technical Chat 2 12-05-2010 12:35 PM
rattle from airbox on cold starts? 2_wheels Technical Chat 7 04-27-2009 11:12 AM
