which kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by s2kvtak, Aug 26, 2009.
  1. Aug 26, 2009 at 8:18 PM
    s2kvtak
    s2kvtak [OP] Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    im new to tacomas and actually dont even have one yet, but whats a good kit to buy? i dont want huge just a little more. so probably 3" or less. i have seen several different kinds. coil spacers with blocks for the rear. heard you can get axle wrap with those=bad. spacers with shakles for the rear,=?? then i have also seen both of those rear options with a different spacer tophat for the front struts. whats a good way to go with minimal wear and tear that can be installed in my drive way with normal handtools? thanks for the help all!!
  2. Aug 26, 2009 at 10:11 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well first we need to know what kind of truck you got. And you want to spend, and the purpose of the lift.
  3. Aug 26, 2009 at 11:31 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    id say find a 3" spacer up front with either AAL or shackle in the back.
    i got my kit for $250. its a 2.5" top plate spacer with 1.5" shackles in the back. im swapping the front for coilovers soon, but ive been running this setup and love it. im just looking for that extra .5 inch and a little better ride.
  4. Aug 26, 2009 at 11:43 PM
    Hologram
    Hologram Go with the flow
    Pensacola-Destin, FL 850
    03 Doublecab PreRunner SR5
    hey does that 2.5" and 1.5" level out the truck completly? or does the front sit higher than the rear? casue i see some kits that are 3" front and 2" in back.
  5. Aug 26, 2009 at 11:58 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Mine sat pretty, almost perfectly level, it was awesome. ive done alot of off road and wear and tear tho on it, so the front to me looks like its saggin just a tad, like maybe half inch at the most. but yea, it sits nice and level.
    im running 285/75s with it too no problem. i just want the front to be higher, and i want the front to be higher than the rear.
    check it out
  6. Aug 27, 2009 at 6:28 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    looking at 2 trucks both '04s one is trd sr5 4x4 5spd and the other is sr5 4x4 auto
  7. Aug 27, 2009 at 8:12 PM
    mylittletacoma
    mylittletacoma taco? like the kind you eat?
    Las Cruces, NM
    00 Silver SR5 4X4 SC
    TRD Supercharger, URD 7th injector kit, Gibson Exhaust, Deckplate Mod, Tough Country 5" lift kit, Fabtech coilovers, Daystar 1" bodylift, 35" Kumho Road Venture MT's mounted on Eagle Alloy 185's black 15x8 -12offset, Alpine 9883 deck, Alpine type R speakers all around, Alpine 500w amp to 10"Boston G1 in custom built rear center console enclosure
    the best option if you have about 7 or 800 is the OME 3" kit. get it from toyteclifts.com. there is another option which i am looking at for my 2000. it is the fabtech 3.5" lift coil over. if you go through www.hopupracing.com it will be 799 for the coilovers, AAL and performance struts in the rear. all you need after that is a dif drop kit to help with the driveline wear.
  8. Aug 27, 2009 at 8:33 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    dont want a coilover b/c they are going to be over 3" plus adding the diff drop= too much money spent.
  9. Aug 27, 2009 at 8:38 PM
    ETaco23
    Evan
    PNW
    What ever you do, dont go spacers up front. Well you can but trust me you wont like the ride. It will be stiff and harsh. If you can, go with the 3" OME lift kit from Toyteclifts.com.
  10. Aug 28, 2009 at 5:17 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    I like my spacers, they've served their purpose and the ride wasn't half as bad as people make it out to be.
    It all depends on the driver, and what they want out of it.
  11. Aug 28, 2009 at 6:47 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    do it right and get an adjustable coil over system with aal's for the rear. do not get blocks for you will have axle wrap like no other. you can get a fabtech 3" adjustable coil over kit for 600 bucks. my two cents.
  12. Aug 28, 2009 at 7:18 PM
    ETaco23
    Evan
    PNW
    True! But I had 3" spacer lift and hated the rough ride on road. It was terrible. Maybe a 2.5" lift isnt that bad, I dont know. But your right, it depends on what he does with his truck, and what he wants the lift for.
    IMO and xspearience Spacers are rough and terrible!
  13. Aug 30, 2009 at 2:15 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    the truck wont be a crawler, but there will be some minor trails probably and some mudding. i just want to make her look a little bigger. this is my first 4wd so i wont need something crazy. i wont take full advantage of it. i found this lift here: http://store.fatbobsgarage.com/shar...944770455&CategoryID=7702&Target=products.asp that uses a strut extension it says. its made by rough country but would that still be strong?
  14. Aug 30, 2009 at 2:16 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    okay well it didnt copy correctly so its the 6th item down. the 2.5" rough country lift
  15. Aug 30, 2009 at 2:33 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    is yours 4x4? you should look into a differential drp so ur CVs aren't stretched
  16. Aug 30, 2009 at 2:39 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    it is. its an 04 x-cab 4wd. i have thought about the diff drop, but i thought that as long as you stayed under 3" it didnt really have much affect? what does droping the diff include? pretty easy task?
  17. Aug 30, 2009 at 2:41 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    its really easy, i installed one on my friends truck. its just longer bolts and spacers.
    you should be good with 2.5" lift. but when your flexed your CVs will be under pressure, but you said you wont be doing anything hardcore so i wouldnt worry about it. its like the same thing as getting new UCAs. its not mandatory but its looked good upon.
  18. Aug 30, 2009 at 2:56 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    UCA's? sorry im from the racing side of the car/truck world so im not familiar with that yet. i have been in the honda game for a while now
  19. Aug 30, 2009 at 2:59 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i have a spacer lift and if your just wanting to clear larger tires and the cheap way out then spacers would work.. the ride is rough.. and its not worth it.. if you want a true 3 inches then go with a coil over lift so even if it does sag in the front a little you can always adjust it up a few more clicks to level it back out.. mine is starting to sag again and i need new leafs in the rear truck008_0e8e4bd89686578d351ecccce31f78c1eded49ec.jpg
  20. Aug 30, 2009 at 3:00 PM
    98_Mud_bug
    lucedale Ms.
    UCA's are the upper control arms.. total chaos makes some
