1998 Tacoma, Help with a tire issue.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Relur, Sep 6, 2009.
  1. Sep 6, 2009 at 1:40 PM
    Relur
    Relur [OP] Active Member
    Springfield, MA
    Hi mentlegen,
    So, I just did a test drive a 1st gen tacoma I might be buying.
    I had noticed that the rear passenger side tire is ready to be replaced(tread wise). While all the other tires have a little more than 40% tread left on them.
    The seller side something about the drive being on the passengar side. Any help? Along with that, I ran a carfax on it and it said it was involved in a front impact. It hit a motor vehicle. But the vehicle was still functional.
    Buy or Run? he wants 5500, its a 1998 black tacoma 4cyl, 5spd, 4x4.
    Thanks.
  2. Sep 6, 2009 at 3:00 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    its all about if you like it. Did he do a lot of off road in his 4x4? might be moe used if that is the case. Hit www.kbb.com to determine market value
  3. Sep 6, 2009 at 3:43 PM
    Relur
    Springfield, MA
    To be honest, I would love to have the truck. Im just wondering if the tire thing is a precursor to other problems?
  4. Sep 6, 2009 at 3:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think the driver side is the drive tire.
  5. Sep 6, 2009 at 3:53 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    might b from doin burnouts
  6. Sep 6, 2009 at 5:36 PM
    Relur
    Springfield, MA
    so burnouts could cause 1 tire to be more worn than the other back tire?
  7. Sep 6, 2009 at 5:38 PM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    yea if it has an open diff. im not sure that truck has 1. i had a blazer in high school that i did that 2
  8. Sep 6, 2009 at 6:19 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    chris4X4 said my truck had a open diff on it, so its possible the 98 u looked is the same. yeah, that would be a good reason (him doing burn outs) to have 1 tire wore, especially if he had never rotated the tires.
  9. Sep 6, 2009 at 7:19 PM
    Relur
    Springfield, MA
    is an open diff good or bad?
  10. Sep 6, 2009 at 7:36 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    More importantly how does it drive ? It sounds like the seller was maybe a little neglectful. Is it tight? Drive straight? More or less mechanically sound?Toyota or not you don't want to plunk down hard earned money on ANY vehicle of ANY brand that is going to cost you more to make it reliable than its worth. Open diffs are actually easier on tire wear than limited slip or locking diffs, but it all comes down to driving habits etc;.
  11. Sep 6, 2009 at 7:52 PM
    Relur
    Springfield, MA
    It seemed to drive well. The clutch seemed fine. The issue is that I am not very knowledgeable in cars. It does drive straight. How do you define tight?
  12. Sep 6, 2009 at 10:08 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    The truck has an open diff. All first gen taco's did. If you had the TRD package with the V6, you go a selectable locking diff (meaning it's open until you hit a button, then it's locked.)
    I'm pretty sure the drive wheel is the pass rear side.
    I drive kinda spiritedly sometimes, and my pass rear has less tread than the other 3 tires.
    Basically, anytime you can hear your tires making extra noises, those tires making the noise is losing tread at a faster rate than the other tires.
    Once I get new tires I'll probably drive more sane....but until then I'll keep trying to slide thru turns. If anything, it'll help me get new tires sooner!!
  13. Sep 6, 2009 at 10:24 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I define tight as not being a total rattle trap going down the road, if it makes too much noise bolts are loose or worse brackets are broken , welds cracked & or broken, frames bend and not always straighten back 100 % in layman's terms there is alot of vehicles out there that are beat to shit beyond normal, avoid these if possible.
  14. Sep 7, 2009 at 5:55 PM
    Relur
    Springfield, MA
    Would it be wrong to offer what KBB says?
  15. Sep 7, 2009 at 6:10 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    What is KBB compared to what he's asking? DEFINATELY would not offer what he's asking, if it's more than kbb. I'd try $750 - $500 low - all he can say is no.
    Do you know a reliable mechanic who can check it out for you first?
    In the end, it comes down to what you think of the truck and how badly you want the truck.
  16. Sep 7, 2009 at 6:17 PM
    Relur
    Springfield, MA
    KBB says 4500-4750 and he is asking 5500. And yes, I do have a mechanic.
    But how does one get the truck inspected at a mechanic before the sale? Just kinda wondering, Im never been in a private sale before.
    In MA we have a lemon law which means, you can get it inspected 30 days after purchase and if anything is super duper wrong they have to give you back your money. It usually ends up in court from what I hear about people's experience's with it.
    EHHHH
  17. Sep 8, 2009 at 9:25 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    the passenger tire being bald is a sigh that someone was burning the tires to the point of serious smoke. Is this a sign on anything? just stupid if you are trying to sell it
  18. Sep 8, 2009 at 12:14 PM
    pittim
    Pennsyltucky
    Boujee Prius
    I've never gotten my tires to smoke, and they've been made to squeal many times.
    plus, one wheel burnouts are lol.
  19. Sep 8, 2009 at 12:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Me either. I had the e-locker. May be that is why my driverside tire always had less tread?
