1995 Tacoma 3.0 low power
Old 09-28-2009, 01:16 PM   #1
scottmo [OP] scottmo is offline
scottmo is on a distinguished road
scottmo's Tacoma Gallery
Truck has 35x12.50 tires 5.29 crawlers front and rear. Locker in front runns great at idel and mid-range highway speed 5th gear maybe 60 to 62 at best not missing or back frieing. New cap and roter and fuel filter. any idea on were to look next thanks.
Old 09-28-2009, 01:43 PM   #3
Haven't had to add any water and isn't getting hot??????????????
Old 09-28-2009, 02:09 PM   #4
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
Mileage on the truck?
Old 09-28-2009, 02:27 PM   #5
98000
Old 09-28-2009, 02:42 PM   #6
:POOPCORN:
98tacoma27's Avatar
Marines:
http://www.ncttora.com/fsm/1990-1995...e/timingbe.pdf
You are at the timing belt interval change with 98 k on the clock. It sounds like you may just need a good tune up. Check your compression and change your plugs.
Old 09-28-2009, 03:06 PM   #7
Haven't changed plugs in a while could this cause low power????????????
Old 09-28-2009, 03:40 PM   #8
:POOPCORN:
98tacoma27's Avatar
Marines:
It is a good starting point and easy to to do. It is possible. Here is a good chart on how to "read" your plugs. Make sure the new ones are properly gapped.
Old 09-28-2009, 07:29 PM   #9
blkcoma32 will become famous soon enough
blkcoma32's Avatar
blkcoma32's Tacoma Gallery
its ran fine until now? how long have u had it?
Old 09-29-2009, 08:26 AM   #10
About 6 months will the large tires and larger gear have that much effect?????????
Old 09-29-2009, 09:49 AM   #11
blkcoma32's Avatar
it just happened since u put the tires on and gears in?
Old 09-29-2009, 12:41 PM   #12
Before it wasn't as sluggish as it is now when you go from first gear to second you have to work the gas peddle it acts like it doesn't want to go kinda hesitata haven"t changed plugs or cleaned throttle body yet hope that is the problem and mayby clean the injectors?????????
Old 09-29-2009, 02:20 PM   #13
ubermx5 is on a distinguished road
ubermx5's Tacoma Gallery
Send a message via AIM to ubermx5
Well these tires will suck the power out of a motor that was lacking power to start with..
You may want to research a way to adjust the Clock spring on the Air box.
Then adjust the gap in plugs. Add a hotter coil pack and make sure all the grounds are clean and the battery is strong.
When I worked at the dealer and saw a few hunder of these get rebuilt do to head gasket campain we sent a few out for porting polishing.
THese motors neve did much even when you did do everything right.
But 20 HP can befound with adding a hotter spark and better air flow and headers...
But you need to research this. It is not legal in all states.
Old 09-29-2009, 06:13 PM   #14
Large Member
Werloc is a glorious beacon of lightWerloc is a glorious beacon of lightWerloc is a glorious beacon of lightWerloc is a glorious beacon of lightWerloc is a glorious beacon of lightWerloc is a glorious beacon of light
Werloc's Avatar
Werloc's Tacoma Gallery
35" tires..?? Uh, yeah.
Old 09-30-2009, 05:54 AM   #15
wolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud of
wolfgang123's Avatar
wolfgang123's Tacoma Gallery
yeah really dude if all this happened when you re-geared and put on 35" tires, then that is your problem
Old 09-30-2009, 06:01 AM   #16
Thanks for the info I will try the air box and coil pack idea. Thanks
Old 09-30-2009, 06:01 AM   #17
NorCal Rock Whore
Killer Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shed
Killer Red Taco's Avatar
Killer Red Taco's Tacoma Gallery
Ok the 5.29s will spin those 35's without a problem. My 89 had a 3.0 5.29's and 35's and no problems and still had ok power even with a dead cylinder. A 3.0 will never win races and was underpowered from the factory.
No mater what you do to it to get power it will still suck.
I bet your HG's are failing. Check your oil!! If the oil is ok run seafoam through it. Also clean your airfilter, change your fuel filter. If you get really crazy put a leak down tester on the engine.
Old 09-30-2009, 08:51 AM   #18
bite me
humanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shed
humanoid's Avatar
humanoid's Tacoma Gallery
These 3.slow engines are notorious for being under powered. BTW, you have a Hilux, not a Tacoma.
Low end power John83 4 Cylinder 4 11-15-2011 02:30 PM
Amp cutting out from low power. mrmumbels Audio & Video 17 07-07-2011 08:50 AM
Low end power rockinray 2nd Gen. Tacomas 3 09-07-2010 09:09 AM
1998 tacoma no power down low 98taco5 1st Gen. Tacomas 2 05-23-2009 01:57 PM
Amp power too low to push sub? ShoeDr Audio & Video 7 03-18-2008 12:29 PM
