Which Add A Leaf is best??
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Nov 6, 2009.
  1. Apr 16, 2010 at 10:10 AM
    #21
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The "Other" aals have Square Cut Ends (hard on the rest of the pack) and are usually much too thick of material. They are also generic aal for use on a number of makes and models of vehicles. Both our Single AAL, and 3 Leaf AAL kits are designed for your Tacomas. They feature Diamond Cut Ends, Anti-Friction pads and fit between the clamps on you factory springs. No removal of the factory clamps is required. The single AAL kit is great for those who do use their trucks for work and need some extra stiffness to help prevent sag. The 3-Leaf kit provides a great smooth ride that works great both on and off-road. Both kits provide approx 1.5" of lift.
  2. Apr 16, 2010 at 10:21 AM
    #22
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2 this no squeaks, improved load carrying, not a bad ride quality just a little stiffer. Not sure on flex tho
  3. Jun 13, 2011 at 10:45 AM
    #23
    kills4kiks
    kills4kiks Well-Known Member
    Adam
    CALI
    05 PreRunner SR5
    murdered out, Halo H.I.D. Head lights, Icon coilovers, aal, pro comp 3000 struts, powder coated rims, Hella Black Magics
    with the fab tec aal did you need new hardware like U-bolts, center pin, etc or did it work with all the old hardware?
  4. Jun 13, 2011 at 10:56 AM
    #24
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    In my case, I just re-used all the original hardware but that was because it was all still brand new. I had just had the frame replaced and had brand new rear leaf springs and hardware, if it had been the old stuff I would definitely have bought new hardware and u-bolts. It has now been over a year with my fabtec's and no problems at all. No squeaking, the teflon tape I used has held up well, and the AAL's themselves have not flattened or harmed my stock springs. If you have the money it'd probably be best to go with the wheeler's long AAL or the 3 leaf pack, but if you're on a tight budget the Fabtec's aren't terribly bad, I like em.
  5. Jun 16, 2011 at 9:39 PM
    #25
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    Sweet i have mine siting in my truck waiting to get put on!
    I'm thinking about putting them on this weekend hope the ride doesn't get too stiff -_- we will see haha... i just got tired of hearing my truck bottom out and slam into those bump stops.
    where did you put the Teflon tape in your install? like inbetween the leafs?
  6. Jun 17, 2011 at 4:10 AM
    #26
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I put about 4 layers on each end, where the AAL will rub against the OEM leaf the most. I can see where getting an AAL with the anti-friction pads already installed would be a good thing, but the stuff I put on has lasted just fine with no hint of squeaking at all. As for the ride, it will really depend on what you have in the back. When I first installed mine I had a big, heavy cap and the ride actually improved. I took the cap off and put a tonneau cover on and it's a little bit harsher, so I tied in 2 sandbags and the ride has smoothed out again.
  7. Jun 17, 2011 at 4:31 AM
    #27
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    x2...some people told me the ride was stiffer with a single AAL, so i bought a wheelers 3 leaf. running it with the overload still installed and i have absolutely no regrets.
    hueman562 likes this.
  8. Jun 17, 2011 at 5:01 PM
    #28
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I have the Fabtech AAL too , its nice. I got 2 inches of lift!
    Thoy likes this.
  9. Jul 23, 2011 at 1:08 PM
    #29
    kills4kiks
    Adam
    CALI
    05 PreRunner SR5
    I finnaly instaled my Add A Leaf and ... I LOVE it! Pluss i droped the bilisten 5100s and threw in some ProComp 3000 struts.... Rides sooo Smooth on and off road Especialy with a load in the back. Highly recommend it!
    P.S. when you buy struts for the rear dont get the expensive gas charged ones ... our truck beds are so light you dont need them.
    ProComp 3000s PERFECT!
  10. Jul 23, 2011 at 1:11 PM
    #30
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    icon progressive AAL.
  11. Feb 19, 2014 at 7:45 PM
    #31
    Chilli Taco
    Chilli Taco Senior Member
    NC
    2010 4x4 SR5 V6
    Toyota Front Bug Guard, Vent Shades, UWS Low profile Toolbox, Husky Floor Liners, Tacoma Rubber Bed Mat, 3 ball with tow hook trailer hitch, Nerf bars, EZ clamp on tailgate, overhead console with compass and temp, Transmission smoothness TSB, Rear 4 leaf spring pack TSB with 4 new Bilstein TRD shocks, Back up camera, JBS Keypad Entry, 2" blind spot safety mirrors, Leaf spring squeak TSB spacer discs,TSB AC/Heater Blower motor 04043, aFe Pro-Dry S Air Filter, Toytec AAL for TSB leafs, TSB redesigned headlights, GMC 5702KA Bulbs in DRL's, DRL switch mod, Illuminated 4x4 switch mod, 2010 4runner heated signal mirrors with puddle lights and 2013 Tacoma color matched mirror covers, bed lights, NOS GMC under hood reel light, TacomaWorld.com sticker on back window,fog lights on anytime mod, hidden ignition kill switch, TRD Skid plate painted black, TRD front recovery hook, console vault, Avid Off-road Light bar, 6" KC Daylighters
    Toytec 1.5" AAL for TSB leafs.
  12. Feb 19, 2014 at 7:46 PM
    #32
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Wheelers heavy duty 3 leaf AAL.
  13. Mar 7, 2014 at 12:12 PM
    #33
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    anyone with any of these add a leafs whether progressive or single in a 2nd gen taco, have any drive line vibrations?
  14. Mar 7, 2014 at 4:03 PM
    #34
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    anyone know if I can add to the Deaver J59 8-leaf pack ?
    I wouldn't want a stiffer ride than I got with that set of springs but the lift is soon lost with any kind of a load in the bed and then I'm running around with that Cali-lean, nose in the air look.
  15. Oct 18, 2014 at 3:55 PM
    #35
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    So...
    Progressive add-a-leaf vs. a single leaf
    What are the pros and cons
    Is ride stiffness really the only factor?
  16. Oct 18, 2014 at 4:17 PM
    #36
    flatblack
    CDA
    thanks for the reply!
    so, the progressive pack is less stiff and stronger
    my main concern with wanting to add-a-leaf is so I can throw more than 30lbs back there without hitting my bump stops; so, that's a big plus for me
    any pros with the single besides saving $$?
  17. Oct 18, 2014 at 4:29 PM
    #37
    flatblack
    CDA
    Haha! That's a bit of an exaggeration; but, yes, I do need new shocks; that's part of the plan
  18. Jan 14, 2017 at 7:39 AM
    #38
    Silver taco 09
    Silver taco 09 Well-Known Member
    2009 silver Tacoma
  19. Jan 14, 2017 at 8:40 AM
    #39
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm running the Fabtec single AAL. It was 2 inches to long in the front when I tried to install. It ended right on top of the clamp for the spring pack. I used a chop saw and cut 2inches off then smoothed the edges off.
    (yes I tried both directions)
  20. Jan 14, 2017 at 10:36 AM
    #40
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I have the 1.5" ToyTec AAL w/ the overload left in & Icon 2.0 smooth body shocks. It sits level w/ the 3" lift up front empty. Rides just fine, even with a bed full of firewood. Although having a D.C. My bed is shorter than a normal size bed. It does sag in the back w/ the bed full. But has never hit the bumpstops. We all know AAL's are just a band aid compared to replacing the whole leaf pack. I also have 252k on the original leaf pack. So it is about time to replace. I don't haul much that often though. So that's why I haven't spent the extra coin for new leaf packs. Here's a picture of it w/ Red fir & Cedar in the back.
