2002 Tacoma Airbag Light
Old 11-09-2009, 08:32 AM   #1
ivass [OP] ivass is offline
ivass is on a distinguished road
ivass's Tacoma Gallery
Hi all,
The airbag light on my 2002 Tacoma PreRunner is on. I've read a few post that talk about shorting 'two pins' and counting the pulses of the airbag light to determine the error code. I can't, however, fine the instructions as to what two pins to short and how to determine what the pulse sequence represents in terms of an error code. Could anyone point me in the right direction?
Thank you in advance,
Ivo
Old 11-09-2009, 08:33 AM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Does your horn and cruise control work?
Old 11-09-2009, 08:35 AM   #3
Horn does (I use it often), but I am not sure about the cruise control .... are you thinking a fuse?
Old 11-09-2009, 08:36 AM   #4
chris4x4's Avatar
I was thinking the Clock Spring....or whatever its called....
Old 11-09-2009, 09:38 AM   #5
It is a possibility, even with the horn and cruise control working. I know that this is one of the items tested, but without and error code, I can't tell.
Old 11-09-2009, 07:11 PM   #6
jpg366 will become famous soon enough
jpg366's Tacoma Gallery
x2 ... that's the wire assembly that carries signals for airbag, horn, cruise, and any other steering wheel mounted controls. You might have noticed the wheel squeaking at full lock, particularly in cold weather. The beginnings of clock spring failure.
Replacing it requires removal of the air bag, so it's somewhat dangerous to do. Best left to a mechanic.
Old 11-10-2009, 07:21 AM   #7
Thank you guys. This is all good stuff, but does not answer my question. I need to know what two pins I need to jump in order to be able to reset the airbag light and to 'reed' the error code. Anyone?
Old 11-10-2009, 07:22 AM   #8
chris4x4's Avatar
Get an OBDII scanner to read it...Not sure about jumping pins..
2006 tacoma airbag light is on bulldogmantrd 2nd Gen. Tacomas 14 05-18-2011 03:07 PM
2002 steering wheel airbag chadd925 1st Gen. Tacomas 3 02-18-2011 03:50 PM
Airbag light + Airbag OFF = Frustrated JMan551 2nd Gen. Tacomas 4 09-23-2010 11:24 PM
2002 Tacoma Brake/Turn light issue. Torqd 1st Gen. Tacomas 4 05-15-2010 09:53 AM
2002 2.7 Tacoma Check Engine Light w/ Code Wood's Double Cab 1st Gen. Tacomas 2 03-01-2010 12:53 PM
