3 inch lift
Old 03-31-2008, 03:58 PM   #1
x1bowhunter55 is on a distinguished road
x1bowhunter55's Tacoma Gallery
3 inch lift
I want to put a lift on my tacoma and I have 31 inch tires and I dont want to put anything bigger because I have the 2.7 engine and dont want to lug it down. Does anyone have a lift with 31's
Old 03-31-2008, 04:07 PM   #2
668: The Neighbor of the Beast
Toy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shed
Toy4Life's Avatar
Toy4Life's Tacoma Gallery
Old 03-31-2008, 04:11 PM   #3
Toy4Life's Avatar
I have 33's now, but that picture was after the lift, but before the 33's.....they were the 265/70/16 stock size tires (31's)
Old 03-31-2008, 04:28 PM   #4
Carolina Alliance Costal Div
2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of2003greenbean has much to be proud of
2003greenbean's Avatar
2003greenbean's Tacoma Gallery
it looks alot better now
Old 03-31-2008, 04:33 PM   #5
Toy4Life's Avatar
I agree.
Old 04-02-2008, 06:14 PM   #6
Redneck from the hills
cbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shedcbcs1987 is one of the sharper tools in the shed
cbcs1987's Avatar
cbcs1987's Tacoma Gallery
Do you have a link with more pics of your truck with 33's? Also, do you just have a basic 3" suspension lift. I'm new to everything so i'm curious.
Old 04-02-2008, 06:36 PM   #7
Toy4Life's Avatar
http://www.tacomaworld.com/forum/whe...s-finally.html
I have a Toytec 3" lift. Coil spacers up front and AAL in the rear.
Old 04-03-2008, 07:56 AM   #8
same lift i have
Old 05-10-2008, 07:54 PM   #9
thenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud ofthenrie has much to be proud of
thenrie's Avatar
thenrie's Tacoma Gallery
I'm gonna jump on this thread. Do your 33s clear ok with the 3" lift? I'm seeing that 32s are the tallest recommended tire for that. I'm running 31s now, but wanting to go to 33s.
th
Old 05-12-2008, 04:56 PM   #10
hicksy712 is on a distinguished road
hicksy712's Avatar
hicksy712's Tacoma Gallery
I had an extreme truck toyz 3" on my 97. more of a show than go kit but definately put 3" under it. i ran 325x65r15 (31x12.50+)bfg mts on a 15x10 wheel with some minor bumper rubbing (just noisy at full lock, didn't hurt anything)
Old 05-12-2008, 05:06 PM   #11
Toy4Life's Avatar
th
How ya been thenrie? I've been offline for a few days. Anyway, I had some minor fender well rubbing at full lock. I was able to take care of it with the pinch weld mod. http://www.customtacos.com/tech/index.php?article=9
It's rare, but once in a while I get some rubbing when I'm wheelin, but I havn't figured out where exactly. I only hear it for a second and the tires aren't getting chewed up, so for now I assume it's just some contact with inner fender plastic. Keep in mind, however, I am running aftermarket wheels with less backspacing than stock.
Old 05-16-2008, 09:56 AM   #12
jayheath2002 is on a distinguished road
jayheath2002's Avatar
Army: UH_60 Helicopther Mechanic
jayheath2002's Tacoma Gallery
I have 33s on my 2.7 Taco. Its a 5 speed, so it moves them just fine and crawls well offroad. They are mounted on the factory 16" rims w/4.5" backspace. The BFG M/T lugs that have T/A writen i=on them will sometimes rub the upper control arm when the suspension is fully extended.At full turn the tires also rub the frame, but I rairly turn that sharp. Under normal driving conditions there is no rubbing. A set of after market wheels with a tiny bit of offset would solve my rubbing issue. Be careful not to have to much offset because then the tires will rub the cabs pinch weld. There is a pinch weld mod for that problem if you have it. Here is pics with 2 1/2" lift w 31" tires and another pic w/33" tires.
Old 05-16-2008, 01:32 PM   #13
thenrie's Avatar
Hey Toy4life! I've been too busy with life to mess with my Taco lately. Thanks for your response and the link. I may just go with that 3" lift. Cheaper is good. What backspacing do your rims have? I'm hoping I can stick with my stock rims. As a matter of fact, I will probably go with metric tires or see if I can find a 33X10.50 with a reasonable all-terrain tread. Since most of my travel will be on-road for the next couple years, I'd rather not carry the extra spinning weight of 33X12.50s.
Old 05-17-2008, 07:51 PM   #14
Toy4Life's Avatar
My wheels have 4" of backspacing. I didn't want 12.5" wide tires, but finding 33/10.5's doesn't leave you with many choices. BFG AT, BFG MT, Super Swampers were the only ones I could find in that size. You could run 285/75/16 on stock wheels, but may need spacers. 265/75/16's might be the better choice. They're 32" tires that still look pretty good with the lift, they'll be cheaper, and virtually any tire out there comes in this size. Honestly, when the time comes to replace my tires, I think I'm gonna get 32" instead of 33". Just some food for thought.
Old 05-18-2008, 04:49 PM   #15
trailinTaco is on a distinguished road
trailinTaco's Avatar
trailinTaco's Tacoma Gallery
My truck is the black one on the right. I have a 2 1/2 inch lift with 33's with aftermarket wheels that have an inch more offset. When I first put the tires on it was rubbing at the back of the wheel well. I trimed a small piece of the wheel well out and it doesnt rub anymore.
Old 05-19-2008, 05:48 PM   #16
thenrie's Avatar
Thanks. That helps with the decision. 33s and a 3" lift it is.
Old 05-20-2008, 04:55 PM   #17
Carolina Alliance: Quack Addict
01TacoTRD will become famous soon enough
01TacoTRD's Avatar
01TacoTRD's Tacoma Gallery
Send a message via AIM to 01TacoTRD
What kind of 2.5" lift do you have? I'm thinkin about puttin one on mine and I'm trying to find a good 2.5" lift
Old 05-21-2008, 03:20 PM   #18
offroadTRD will become famous soon enough
offroadTRD's Avatar
offroadTRD's Tacoma Gallery
hey 01Taco, just trying to help you a little if you want it. My 2000 ext.cab 4x4 Trd manual tacoma has 33x12.50-15 maxxis buckshot mudders on it. I have a Fabtech 3" adjustable coilover system in the front and 2" add-a-leafs in the rear. I also have a 3" Fabtech body lift as well. This lift is great!!! I also bought 15x10 American Racing type-23's wheels. I bought all of this from National Tire & Wheel for about 1800 bucks. But you can knock off 440 bucks of that price if you stay with your stock wheels. By the way, I love this truck. I hunt with it nonstop during hunting season hard. Hasn't let me down and handles high speed logging roads like a dream and is great in ruts and harsh terrain. Just my 2 cents though. This same lift will bolt right to your truck if you plan on getting it.
Old 05-21-2008, 05:40 PM   #19
2.5" coil spacers in the front and 2.5" add-a-leafs for the rear. its made by Daystar and at a really good price. I got it for $170 on 4wheelparts.com. I keep my front struts stock but I had to replace the rear because they were short. I put longer shocks by Fabtech for about $90. that was separate to the lift kit.
16 inch rims with a 6 inch lift kit kinkrider101 2nd Gen. Tacomas 19 03-31-2014 07:51 AM
3 Inch TOYTEC Ultimate Lift OR RCD 4.5 Inch Lift Kit? FXHO 2nd Gen. Tacomas 17 08-08-2013 01:37 PM
3 inch Toytec with 3 inch body lift with 33s BAMATOY Suspension 12 01-25-2013 07:40 PM
tough country 3 inch spacer lift or fabtech 3 inch coilover? jd17usmc 2nd Gen. Tacomas 22 11-13-2012 12:11 PM
3 inch body lift on a 6 inch fab tech lift bruth Suspension 17 05-08-2010 12:58 AM
