1996 2.7 injectors won't spray
Discussion in '1st Gen. Tacomas (1995-2004)' started by linkedyota, Mar 1, 2010.
  1. Mar 1, 2010 at 4:26 PM
    linkedyota
    linkedyota [OP] New Member
    max
    nottingham, NH
    1996 toyota tacoma 37" boggers
    6" suspension, 3" body lift, 37" boggers on 15" incubis offroad rims, welded rear, custom bumpers
    I blew up my 1996 tacoma's 2.7 with 220,000(bad head gasket). I found another engine for $150 swapped it in this weekend and at first had some spark issues and redid all of my grounds and timmed the new engine. now im not getting fuel. the fuel pump works, fuel filter was changed, swapped out my injectors and rail and i am getting fuel to the rail. I'm getting power to all of my injectors but they aren't dumpin fuel in. I thought resetting the computer might help but didn't seem like it did a thing. any help would be awsome..
  2. Mar 1, 2010 at 4:36 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    did you just swap in your old injectors?
  3. Mar 1, 2010 at 4:37 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Were you previously getting fuel to the new engine (when you were dealing with the earlier issues), and now you're not? Or ... Have you never gotten fuel to the new engine?
    What year / model Tacoma did the 'new' 3RZ come from?
  4. Mar 1, 2010 at 4:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe the injectors need to be cleaned.....sitting for a good while can cause them to clog bad.
