Door Chime Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by COMAtized99, Mar 31, 2010.
  1. Mar 31, 2010 at 10:40 AM
    COMAtized99
    COMAtized99 [OP] Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Ok i know alot of people know this already but i havent seen any with pictures so i figured i would write this up.
    This will show what you need to do to make the door chime not work with key in, turned to ACC, when you turn the key to ON the chime works as normal, I have not had any problems with this mod.
    I am sorry for the Blurry pictures. they are from my cell.
    These pictures are of a 99 tacoma 4x4 3rz auto ext cab, and a 96 tacoma 2wd 2rz manual reg cab.
    This mod took me all of 5mins and worked like a charm...or should i say chime:D
    Ok you will need to remove the cover from under the dash, it is attached to the hood release. there are 4-10mm bolts and one phillips head screw. the cover will swing down far enough to have complete access to the plug you need to unplug with the hood release still attached.
    This picture is for the 99 taco's but the 96 was just the same. (cover removed)
    This is also the 99(small white plug still plugged in)
    This also is the 99 (small white plug removed)
    ________________________________________________________________________________
    This is the 96 taco, this Blue plug only has two wires running to it, it plugs into a black connector.
    96 Taco plug in.
    96 Taco's plug unplugged.
  2. Apr 20, 2010 at 6:32 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    UPDATE:
    on my 99 tacoma. there are more wires that where unplugged than on my 96 tacoma. my 99 is a SR5 model. it has power door locks as a part of the package. my 96 is a base model. power nothing... in my 99 taco if you leave the keys in the ignition and lock the doors with the doors open it would unlock them right after you tryed to lock it. now with the plug unplugged they will lock with the keys in the ignition.
    If you do this mod you better not leave your keys in the ign. and lock the doors and shut em.. your fail safe no longer works.
  3. Mar 31, 2011 at 6:30 PM
    homesweettaco
    homesweettaco Well-Known Member
    Mark
    Nederland, CO
    2000 TRD Black
    Camper shell, yak rack, pop-n-lock, ultragauge, 2 inch suspension lift, K&N Intake, blacked out grill, BHM with clear lenses, debadged, favorite mod: center console from '01 with REAL CUPHOLDERS!
    Thanks for this! The pictures are just clear enough for the purpose so no worries.
  4. Apr 1, 2011 at 6:29 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Interesting. I bought my 03' used and it doesn't have a door chime. I guess another Tacoma "enthusiast" took care of that for me. :)
  5. Apr 1, 2011 at 3:54 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar Toyo Open Country AT/3's Bilstein 5100's up front, (#2) & 4600 in rear Daily driver....
  6. Apr 1, 2011 at 8:14 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Nice write up :)
  7. Apr 2, 2011 at 4:29 PM
    bivey
    bivey Well-Known Member
    Did mine today.
  8. Apr 12, 2011 at 8:19 PM
    tb99trd
    tb99trd Well-Known Member
    Tom
    Petaluma CA
    99 TRD 4x4
    Bilstein 5100s (@ 2.5), Toytec 2" AAL, gray wire mod
    where are the pictures? does this disable the dome light when you open the door too or just the dinging?
  9. Apr 12, 2011 at 8:58 PM
    Madjik_Man
    Colorado Front Range
  10. Apr 12, 2011 at 9:02 PM
    Norton
    Norton Senior Member
    Steve
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  11. Apr 13, 2011 at 9:03 PM
    glamis3000
    glamis3000 Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    or just pull the boot on the door jam and break the little rod off like i did on accident trying to disassemble it.. lol doesn't chime anymore.. lol
