3" Lift & 285s... What do I need to do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mortuusangelus, Apr 23, 2010.
  1. Apr 23, 2010 at 6:55 AM
    mortuusangelus
    mortuusangelus [OP] Well-Known Member
    Michael
    Slate Hill, NY
    no truck now :(
    Ok, I've been reading various threads regarding having a 3 inch suspension lift on one of our 1st gen Tacos and running 285s. I'm looking at 285/75/16s for after I put in the Toytec lift w/ LR UCAs. The question is.. what modification if any do I have to look at for fitting them?
    I'm running ProComp 16x8s w/ 4" BS, so they stick out somewhat more, which should help with rubbing issues. I'm figuring I at least need to do the pinch-weld beatdown... err.. mod. :D Anything else I need to do?
    Can't seem to find any real definitive answers.. some do, some don't but they're also running different setups too.
  2. Apr 23, 2010 at 7:37 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i think you'll still need a small body lift ...unless you wan to do a lot of trimming.
  3. Apr 23, 2010 at 9:02 AM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    I have coilovers up front, at about 2.25 inches of lift and run 285s, only thing i had to do was beat down the pinch weld. No other rubbing issues.
  4. Apr 23, 2010 at 9:12 AM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    i would have said buy a 32" instead of those 33"
    beating stuff in is always my fav
    +1 for quattro
  5. Apr 23, 2010 at 9:46 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Put it on a see how they are. Tires varies along with your car's weight therefore it may or may not rub. If it does, evaluate where and fix/cut accordingly.
  6. Apr 23, 2010 at 9:58 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    My last truck, 04 2wd Pre Runner, had 3" Toytec lift, stock wheels (no spacers) and 285's. Only rubbing was from turning full lock-to-lock, a slight rub on the frame.
    No biggee
  7. Apr 23, 2010 at 10:02 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    what kind of backspacing do your wheels have?
    i still rubbed a bit with 265/75/16's on my last tacoma. i ran adjustable coils set at 2.5" ...it would have ripped my fenders off with 285's.
    i think the key to running 285's must be using stock wheels. ..or wheels with the same specs. ...i had aftermarket wheels with -4" bs ..that may be the difference.
  8. Apr 23, 2010 at 12:48 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive got 285/75/16's and they only rub on lock to lock turn on the frame but i did bend back the pinch welds so when wheeling it doesn't hit my tires when flexing but u can put 33" tires on a Tacoma with 3" lift with minimal rubbing.
  9. Apr 23, 2010 at 1:14 PM
    bivey
    bivey Well-Known Member
    Same here
  10. Apr 23, 2010 at 4:02 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I only have a 2.5" lift with stock rims and 285's. They only rub a little on the frame at full lock. You really shouldn't have to do anything to fit that tire if you can deal with a tiny bit of rub
  11. Apr 23, 2010 at 5:50 PM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    Seems like the minimal rubbing is with stock rims then? Issue for me, considering I destroyed one of my rims and bought new ones. :D
    Hmm.. well, I may go with the 31 or 32s for now, until I can decide how I want to deal with things. Sigh.. decisions decisions..
  12. Apr 23, 2010 at 5:56 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    They make a 285 70 16. The nitto trail grapplers. They a little wider than 75s but shorter. Im thinkin about getting them. I think a 265 75 16 will look good on your truck. If i dont get the nittos im gettin 265 75 16s. When did you get the pro comp wheels and witch ones did you get.
  13. Apr 23, 2010 at 6:58 PM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    Picked up the wheels a couple months ago, bought them off of Wheelers. Black steel, 16x8, the "Type B" ones (4" BS).. ran me just over $400 with shipping, which also included all new lugnuts and the black closed hubcaps.
    I'm running 265/75/16s now.. though the tread is shot to hell (as you saw at Stokes).. Only get rubbing at full lock.. and that's cause no lift. :D Hmm.. probably stick with 265/75 for now.. who the hell knows what I'll wind up doing to my truck in a year.. lol
  14. May 9, 2010 at 6:35 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    don't mean to thread jack but i have a similar dilemma i ordered 285/75/16 duratracs and i have stock rims and uca's i plan on getting LR ucas but not for a bit. my concern is that they will rub on the uca? the tire shop is ordering them tomorrow don't know if i should changed them to a 265 instead to avoid the headaches if they will rub the stock uca. any input on it would be great i really dont know what to do.
  15. May 9, 2010 at 6:50 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Y'all are making me worry now! I have Bilstein shocks at 2.5". I have a set of FJ 17" Wheels that I picked up and want to run 285/70/17s.
    I also have Spidertrax wheel spacers(1.25") that I might run because of rubbing...
    But you guys are saying that I don't need spacers?
    Thanks for the heads up.
  16. May 10, 2010 at 7:00 AM
    sirsaechao
    Tim
    CA
    Worst case for those who are running stock wheels and want to get 285's is you need wheel spacers until you can fund new UCA's or wheels w/ smaller BS. I would put them on and see. There are various factors come into play. The lift kit, wheels, tire mfg (even tho they are all 285/75/16's), you, your truck and etc.
  17. May 10, 2010 at 3:06 PM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    Point there too (tire mfg)... they migbt be 285s but actually turn out smaller than 33 inches, or larger.. depending on tread depth etc. Friend of mine is running a set of those GY/Kelly Fierce Attitudes... in 35s... they are monsterous... closer to 36" and almost 14 " wide.
  18. May 10, 2010 at 5:05 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Either way, the 285's will fit. Just miner trimming and the pinch weld mod, and you will be good man! With your wheels, you shouldnt rub much at all. Get the 285/75's you will be happy!:thumbsup:
  19. May 10, 2010 at 5:25 PM
    BigAndy21966
    BigAndy21966 Well-Known Member
    Racoon City
    Wifeys build 2004 Tacoma TRD
    2.5" Toytec lift Cobra 148 SSB CB radio Soon: Snorkle, grey wire mod
    Wifeys build : 2.5" Toytec lift kit, 285 75 R17 Goodyear wrangler MTRs 17" Motometal skulls with stock backspacing and offset (12MM I think), I had to beat the pinch weld down due to slight rubbing when at full turn. Its a 15 minute job you can do with the wheels on
  20. May 10, 2010 at 8:50 PM
    mortuusangelus
    Michael
    Slate Hill, NY
    no truck now :(
    eh, I'm gonna have everything off when I put the lift on, the pinch weld will be easily modified then. :D
    Sweet info, thanks guys.
