Going back to stock...Losing 6" DB kit. Yes, it CAN be done!
Old 04-23-2010, 09:34 AM   #1
Coolidge [OP] Coolidge is offline
Coolidge will become famous soon enough
Coolidge's Avatar
Coolidge's Tacoma Gallery
As some of you may know, Im getting rid of the POS TM 6" drop bracket lift on my gen 1 (03 Pre Runner 2wd) 9 out of 10 people have told me "It cant be done" Well, it can. Work started yesterday:
Parts:
The crossmember will be cut/trimmed here @ factory seam:
The truck will be trimmed/prepped same spot:
These are were measurements are taken w/tram gauge.
More to come
Thursday 4/21/2010:
The "fun" has begun:
Prep/clean frame
Kit is gone
POS TM struts BLOWN/leaking:
as it was, and never will be again
Its going quite well....
[IMG]http://img.photobucket.com/albums/v25/Guyster/crash2_10_2010027
.jpg[/IMG]
$hit Kit:
Man, I "hope" its straight! lol :welder:
3:00pm same day. Going back together....
Old 04-23-2010, 09:35 AM   #2
Living vicariously through everybody
derekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shedderekabraham is one of the sharper tools in the shed
derekabraham's Avatar
Name: TW'S Hippy Liberal
derekabraham's Tacoma Gallery
Old 04-23-2010, 09:36 AM   #3
Is your King shock bent? It looks bent in a few pictures...
Old 04-23-2010, 09:42 AM   #4
sirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shed
sirsaechao's Avatar
sirsaechao's Tacoma Gallery
I was always under the impression that Prerunner's don't require the cutting of the xmember thus allowing you to be able to go back to stock?
Old 04-23-2010, 09:45 AM   #5
Coolidge's Avatar
No, the top bracket is seperate, and swivels. There is a thru bolt you cant see in pics. Basically that shock will work on many trucks. You just have to get the correct top bracket for your apllication. Not bent
Old 04-23-2010, 09:48 AM   #6
Got it.
Old 04-23-2010, 09:49 AM   #7
Coolidge's Avatar
Yes, this true if Fabtech kit is used, but this was the POS Trailmaster kit. It requires cutting #2 crossmember on both 2wd & 4wd. The TM kit also eliminates UCA's adding a 2nd strut(!) in its place. Its a TERRIBLE lift kit.
Im working on the rear today. Losing the 2.5" blocks, but keeping the AAL's. Hoping the Bilsteins will work OK too. My 315's are getting swapped for 285's today as well
Old 04-23-2010, 10:13 AM   #8
Banned
When I had my Ranger and was looking for a lift Trailmaster offered a kit. It used ball joint spacers.
Looks like you have good welding skills so it should turn out just fine.
Old 04-23-2010, 11:55 AM   #9
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
sweet. Definitely a lot of work for the previous owner's mistake.
Old 04-23-2010, 12:33 PM   #10
sirsaechao's Avatar
Just like I told you. Trail Disaster not Master.
Old 04-23-2010, 01:47 PM   #11
nelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shed
nelson18matt's Avatar
Air Force: Ex-Cone
nelson18matt's Tacoma Gallery
Nice man, your gonna be so much happier. those TM kits are terrifying. what a horrible design.
what are your future plans? mid travel kit all around?
Old 04-23-2010, 05:13 PM   #12
Coolidge's Avatar
OK, Im done!! Truck is at alignment now. I'll have it back to me Sat AM. Will get pics then.
Old 04-23-2010, 05:18 PM   #13
I CANT SPELL SO DONT BITCH
mwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shedmwild is one of the sharper tools in the shed
mwild's Avatar
mwild's Tacoma Gallery
Good job. I never liked the 6" lifts on the 1st gens. The AAL shold work good with 5100s. Thats what i have and it sitts level.
Old 04-24-2010, 12:06 AM   #14
kumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud of
kumaWRX's Tacoma Gallery
Damn that is one weird ass suspension design, it looks so half-ass. Trailmaster must've hired all the grade D engineers, lol.
Old 04-24-2010, 10:31 AM   #15
Coolidge's Avatar
Just back from alignment. Heres a complete pic. Same wheels, no spacers, 285's instead of 35's. Best off, no more DB kit
Hytenor: Align specs before
Align specs after:
Old 02-16-2011, 04:28 PM   #16
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
Finally, another DB hater Nice work man!1
Old 12-28-2011, 07:12 PM   #17
StaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shedStaticFilter is one of the sharper tools in the shed
StaticFilter's Tacoma Gallery
Great to know i have another option with this lift. Wonder if anyone has gone from a trailmaster to a fabtech or similar DB lift...
Old 12-28-2011, 07:21 PM   #18
Carolina Alliance Southwest Region Ambassador
jandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shed
jandrews's Avatar
jandrews's Tacoma Gallery
Yeah, I love shit like that. People seem to forget that metal can be both cut and welded. Or that fabricators can be paid to produce items, such as crossmembers, to custom specifications.
"Can't be done" on here means "isn't bolt-on".
Nice work.
Old 12-28-2011, 07:23 PM   #19
TW's Official anti body-lift pundit
TacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shed
TacoMX's Avatar
EMS: Paramedic
TacoMX's Tacoma Gallery
Good job!!
That looked like it required a lot of head scratching!
Old 12-28-2011, 08:44 PM   #20
mall crawler
Rebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shed
Rebel Taco 22's Tacoma Gallery
Ever cross your mind to SAS while you already had all that crap cut out?
2010 Tacoma DB SB Stock exhaust IslandBoy86 2nd Gen Tacoma Marketplace 2 04-12-2011 04:34 PM
FS: 05+ parts (Going back to "mostly" stock) Shiftin2Sixth Buy / Sell / Trade 45 11-03-2010 12:30 AM
Ultimate Kit and Coilovers back in stock!! ToyTec Lifts ToyTec Lifts 0 08-13-2010 02:16 PM
FS: 6" Trailmaster DB lift kit Gen 1 Coolidge Buy / Sell / Trade 2 05-03-2010 01:04 PM
Going back to stock...no more DB kit. It can be done Coolidge Suspension 4 04-23-2010 10:10 AM
