quick regear question
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, May 3, 2010.
  1. May 3, 2010 at 5:38 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    im runnin 285s on my 01 tacoma v6..... lookin at maybe goin 305s....would regearing to 4.88s do the trick for lost power??
  2. May 3, 2010 at 5:44 PM
    RelentlessFab
    Eric
    Sparks, NV
    whats your factory ratio? 4.88 seems too low for only 33's IMO.
  3. May 3, 2010 at 5:47 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    I would go to like a 4.11 or 4.56 max
  4. May 3, 2010 at 5:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    4.56 should put you back to about stock feeling power wise.
  5. May 3, 2010 at 5:56 PM
    RelentlessFab
    Eric
    Sparks, NV
    yep, same here. This is what i'm thinking, but with my 35's! I want to keep the r's down for better mpgs(I only lost like a mpg with the 35's vs old 32's), but pick up a little more snap that was lost with the big rubber.
  6. May 3, 2010 at 6:14 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    its 4.10 factory
  7. May 3, 2010 at 9:47 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i know some guys who had previously gone with 4.88s...
    they were burning quite a bit of rubber and had to gear back down to 4.56...
  8. May 3, 2010 at 9:49 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    x2 what he said but one of my friend has 35s with 4.88s said the rpms are pretty high on the high way. Ill be going to 4.56 for my taco.
  9. May 4, 2010 at 8:01 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    so i guess 4.56 it is
  10. May 4, 2010 at 9:32 PM
    RelentlessFab
    Eric
    Sparks, NV
    If you want to figure out your equivalent new gear ratio from larger tires, use this as a guide:
    (New tire size)
    ------------- X (current gear ratio) = equivalent
    (Old tire size)
  11. May 7, 2010 at 2:01 PM
    Holden02
    Holden02 Well-Known Member
    Auburn, AL
    '02, SR5, V6, 4X4.
    3" ToyTec Front Coilovers, 3" AllPro Leafs, 4.88 Yucon Gears, ARB Air Lockers Front & Rear, Flex-A-Lite Twin Fan, AT Oil Cooler, Safari Snorkel, 16x8 Black Crawler Rims, 305/70r16 Hankook DynaPro MT's, A-Pillar Dual Guage POD w/ Digital Volt Gauge and AT Temp Gauge, XM Radio, Can-Back Soft Top, Custom Rear Bumper, Electric Brake Box & 7-Pin trailer plug, My Custom Winch Bumper with Cheep 8500 lb. "Vortec" Winch. (we'll see how it lasts)
    I am running 305's w/ 4.88 gears. I really don't notice much until highway speed. The RMS are a little high while running 70 mph. The 4.56 gears will be as close to stock as you will get. 30 to 60 is where I can tell the differance. For a lot of city driving and off road I'd go with the 4.88's all day long. If there is a lot of highway miles 75% or more driving I might go with the 4.56's.
  12. May 8, 2010 at 2:08 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    whats your rpm at going 70?
  13. May 8, 2010 at 5:37 AM
    Holden02
    Auburn, AL
    '02, SR5, V6, 4X4.
    I think it is about 2500 (+ or -) a little. Mainly go by my Speed-O. 70mph on the dash is actually 60mph on the road. 83mph on the dash is 70mph on the road. The max speed is about 87 on the road. By that point the Speed-O is reading past 100mph.
    I when on the highway I run around 65 mph (true speed). I have been averaging about 16.5 mpg.
  14. Jun 20, 2010 at 11:32 PM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    how can you tell your ratio? have a 02 2.7 dc and im about to put 285/75/16s? any help would be awsome. Thanks
  15. Jun 21, 2010 at 2:38 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ^ on the door jam on the driverside there is a sticker there, in the bottom right of this sticker you will see 4 digits like B03A which translates to 8'' ring rear,4.10 gears,2 pinion open. what does it say on yours?
  16. Jun 22, 2010 at 9:36 AM
    jcmartinez17
    jc
    ontario
    mine says bo4a.
  17. Jun 22, 2010 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
  18. Jun 22, 2010 at 10:29 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    whats the difference between a 2 pinion open and a 4 pinion open?
  19. Jun 22, 2010 at 11:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    2 pinion..............see parts 9 & 15
    4 Pinion
  20. Jun 23, 2010 at 11:37 AM
    jcmartinez17
    jc
    ontario
    so i would have to regear for 285/75/16s?
