How to: 95.5-97 Grille swap onto 01-04
Old 06-01-2010, 09:30 PM   #1
STLharry [OP] STLharry is offline
Lube: It's the key to penetration.
STLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shed
STLharry's Avatar
EMS: Charlotte VRS: EMT/Driver
STLharry's Tacoma Gallery
Ok, so, I bought an 01 V6 TRD Taco to replace the old rusting out '96 that I originally had, but I was averse to the billet grille on the new truck and I really like the original Taco face, so I did a grille swap.
Started with 2 trucks:
Removed the hoods, lights, bumpers, and grilles from both trucks:
Swapped the hoods and put ARB mounts on the new truck:
Then moved the truck to a garage and started on the old-style headlight mounts on the new truck. This involved drilling holes in the body panels for the mount/aiming screws and squaring them out with a file. One went behind an existing hole on top of the light, and the other had to be marked and drilled afterward to ensure correct placement.
Filing:
Once the square plastic screw mounts fit, I put them in the holes and added epoxy to make sure they stayed put. Left them to set for the night and day and finished the next evening...
The grille clips are all the same for both styles, so the only modification needed was a little filing on the left side of the main grille part to make it fit in front of a cooling system hose. Then it just slid right on. I also used zip-ties to hold the grille in place because the OEM clips suck and always break after 1 use. It's much easier to use zip ties and just cut them off each time.
ARB mount process, with lights and grille all in place:
There you have it! All finished. Now I have a truly unique truck, not to mention I rid myself of that billet grille.
Not sure if anyone cares or even wants to copy it, but there's what I did. If somebody else would like to follow suit and has questions, feel free to PM me anytime.
Parts swapped:
Hood
Hood latch (the 01-04 hood latch is too tall)
Bumper - I used an ARB bull bar
SAE rectangular headlights and corresponding mounting/adjustment hardware - I used IPF H4 conversion lenses
Grille
Metal trim pieces that attach to grille in bottom corners (purely cosmetic) - I lost the right one while driving in March 2014
The parking lights and fenders do not change.
UPDATE 1/21/14: I did end up changing the parking lights to the older style because while the overall shape is identical, 95.5-97 lights used 2 screws and plastic plugs to mount into the fender and 01-04 lights used a plastic tab. Fortunately, the square holes for mounting the plugs remains unchanged for all 1st gen fenders, so no modification was needed. I simply removed the newer mount, put in the plugs, and screwed in some old-style corner lights from Rockauto. If you want pictures of the process PM me.
Lastly, the 95.5-97 grille will not fit on the 01-04 trucks with a stock bumper that has the color-matched trim piece on the top of it. I did not care because I installed an ARB bar as well but that must otherwise be removed.
Old 12-01-2010, 10:18 PM   #4
4wd tacoma
trd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shedtrd7 is one of the sharper tools in the shed
trd7's Avatar
trd7's Tacoma Gallery
good job
Old 12-01-2010, 10:22 PM   #5
He who angers you conquers you
Unknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shed
Unknown's Avatar
Unknown's Tacoma Gallery
Nice, i want to do that but an 01-04 in my 95
Old 12-02-2010, 07:03 AM   #7
STLharry's Avatar
Originally Posted by SRQ TACO View Post
I want to do a 95 4wd front end on my 00. It should only take the headlights, corner lights, grille, bumper fillers, and front bumper to do on a 00.
You shouldn't need corner lights...the shape is the same for all 1st gens. The only difference is the older ones (like my 96) were held by screws while the newer ones clipped in.
As for the bumper, if there is a little color-matched plastic trim piece on top of the chrome part then you will have to either remove that or get a different bumper. The older bumpers did not have that so the 95.5-97 grilles won't fit if it's there. It can probably be easily pulled off though.
You can use any old SAE rectangular headlights. I went for the IPF ones because a friend had the round ones and he liked them quite a bit.
So you really only need grille, little metal trim pieces that go in between grille and bumper (bumper fillers?), modified bumper, and headlights.
EDIT:I make note of the bumper trim piece in the write-up too.
Old 06-06-2011, 02:35 AM   #8
ilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant futureilove_taco_ma has a brilliant future
ilove_taco_ma's Avatar
ilove_taco_ma's Tacoma Gallery
very nice.
Old 01-24-2015, 05:18 PM   #10
Mikescollins is on a distinguished road
Mikescollins's Tacoma Gallery
thanks
I had to swap my radiator support and the 97 model was way cheaper than the 95 but didn't have the headlight mount holes, you saved me a lot of money and time thank a lot man.
HOW TO: Replace 95-97 side mirror with a 01-04 mirror. trdracing5 1st Gen. Tacomas 35 12-04-2014 01:31 PM
Feeler: 01-04 Billet grille trade for your OEM grille Johnnie Buy / Sell / Trade 5 04-13-2011 08:41 PM
Feeler: 01-04 Billet grille trade for your OEM grille Johnnie Southern California 1 04-13-2011 08:39 PM
WTB: '95-'97 4WD chrome grille and bumpers mbtech208 Buy / Sell / Trade 0 06-11-2009 07:44 PM
get rid of the 97' for a 01' to 04' model? 97YoterS 1st Gen. Tacomas 1 05-13-2008 09:59 AM
