2001 quad cab seems to bottom out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Jun 18, 2010.
  1. Jun 18, 2010 at 9:12 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    My wife and I took my truck out to eat last night and she kept telling me everytime we hit a bump it was rough as ____. I started noticing it feels like the truck is bottoming out over rough roads. I push down on the front and back shocks and they seem fine. Any idea on how to make this better. Rick
  2. Jun 18, 2010 at 9:41 AM
    Ricky B
    Arkansas
    1998 XCAB
    145,000
  3. Jun 18, 2010 at 9:46 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Well there your problem haha
  4. Jun 18, 2010 at 9:48 AM
    Ricky B
    Arkansas
    1998 XCAB
    Yeah I think so. Will go with Blisteens 5100. That is what I'm hearing.
  5. Jun 18, 2010 at 11:40 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i bet your leafs are flat. ....maybe time to upgrade.
  6. Jun 18, 2010 at 3:59 PM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    Not to threadjack.. but how would I tell if the leafs on my truck are gone? They are pretty much parallel to the ground. I'm not really sure if they are supposed to be a "smile" or not. I'm still using the OEM shocks at 94K miles
  7. Jun 18, 2010 at 4:11 PM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    You need new leafs:D toytech has some for like 70 bucks. really good deal!
  8. Jun 19, 2010 at 10:52 AM
    747 function > form
    1st Gen.
    Any links (searched, but no luck on the Toytec website). Thanks in advance!
  9. Jun 19, 2010 at 11:01 PM
    asus611
    CA
    Can I just get an AAL? Or do I / should I get a whole new leaf pack?
  10. Jun 19, 2010 at 11:15 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I think once your leafs are flat, they're pretty much done for. Adding a new leaf may be a temp fix, but without the main leafs supporting it, I think it'd just end up flattening out pretty quick as well.
  11. Jun 21, 2010 at 7:01 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    It's time to do the suspension. I would look into some new coil springs, shocks and leaf pack. Since you need a spring compressor for the front to do the shocks...I would just do the coils now to avoid having to do the alignment twice.
  12. Jun 21, 2010 at 8:20 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Sorry I took so long to get back at you. Here's the link.
  13. Jun 21, 2010 at 4:17 PM
    asus611
    CA
    Ok thanks for the info... I'm trying to avoid turning this vehicle into another mod project...buuuuut since i'm gonna tear things apart might as well lift it, I guess.... :)
  14. Jun 21, 2010 at 6:14 PM
    747 function > form
    1st Gen.
    All I found were AALs for +/-$70.
