Locking rear axle swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by DigB, Aug 30, 2010.
  1. Aug 30, 2010 at 2:29 PM
    DigB
    DigB [OP] Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Is it easy or inexpensive to get a rear TRD axle installed in a non TRD Truck? It comes with the ECU and everything.
    I have an 03 Extra Cab and I found a rear axle out of a 2000 4 Runner, would it fit in my truck?
  2. Aug 30, 2010 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have no idea on the electronics side of the problem but I do know that all the suspension mounts will be different on the 4runner axle. For one, those have coils instead of leafs. So you'd likely have to build spring perches on the axle tube, shackle mounts and front spring mounts on the frame.
    The overall hub to hub width will be similar though likely not identical. 16" stock Tacoma alloy wheels should mount on that axle with no issues, the offset might be slightly different.
    Overall, probably not as difficult as doing an SAS. I am betting that this has been done many times before.
  3. Aug 30, 2010 at 9:27 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    well unfortunately that sounds like a little too much work for this guy so I might just go the way of an aftermarket locker like a powertrax no slip and then buy a TRD OR 2nd gen when funds are available!
  4. Aug 31, 2010 at 7:29 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Buy an aftermarket locker instead.
  5. Aug 31, 2010 at 8:36 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I don't think it would be difficult electrically to integrate, not much to it other than getting power to the acuator/servo to engage/disengage
    via the button you'd have to install but I'd look for a TRD axle approx. to your year truck, FROM a truck not 4runner, but be forewarned, guys are really looking for the TRD Elocker so prices are at a premium, after market may be the way you want to go (ARB setup is great but too pricy for my taste) Auburn, Detroit are options but if you take a little time & keep your eyes open you can find the stock TRD axle, I saw one less than a week ago on Craigs for $ 900.00 OBO, probably gone by now though..... good luck....:cool:
  6. Aug 31, 2010 at 11:32 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I would think that you may be just a well off to just buy a lock rite or a power trax. Probably be alot cheaper and alot less of a headache to install.
    I have rode in a few trucks with this lockers in stalled and they seemed to work very smoothly
