Rancho quicklift
Discussion in '1st Gen. Tacomas (1995-2004)' started by jaytrain, Nov 12, 2010.
  1. Nov 12, 2010 at 7:55 PM
    jaytrain
    jaytrain [OP] Member
    Jackson
    Durango,Co
    1997 Tacoma
    Built a cold air intake,flowmaster 40 series
    Hey everyone I was wondering if any of you guys have rancho quicklift on your trucks? If you do please give me some feed back on what you think of them.
  2. Nov 12, 2010 at 8:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Don't think you'll find too many folks on here using Rancho shocks. A lot of Bilstein users though. Are you planning to lift your '97?
  3. Nov 12, 2010 at 8:19 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I have Bilsteins in the front and Ranchos in the back...
  4. Nov 12, 2010 at 8:47 PM
    fsbrain03
    fsbrain03 Well-Known Member
    I saw these for the first time online last week. They look pretty sweet. Should do the same as a 5100 Bilstein does.
  5. Nov 12, 2010 at 8:52 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    They are not adjustable height wise. I helped install a set on my friend's Frontier.
