need help with keyless entry remote program
Discussion in '1st Gen. Tacomas (1995-2004)' started by George Rockwell, Feb 22, 2011.
  1. Feb 22, 2011 at 9:08 PM
    George Rockwell
    George Rockwell [OP] Well-Known Member
    Tacoma with a ARB bull bar
    very fast
    Hi i did search, i have tried to program my new remote for my 03 tacoma, with the door open key on off think, NO LUCK , i have 3 different type remotes, i have two with out red light and one from a tacoma with red light, please some one help me with this, Thanks.
  2. Feb 23, 2011 at 10:06 AM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    are the remotes the correct ones for your truck? Do you have a FOB that works and the ones your trying to program are the same part#?
  3. Feb 23, 2011 at 10:59 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Just purchased truck used, remote not working. Changed battery, still doesn't work. Help!
  4. Feb 23, 2011 at 6:41 PM
    George Rockwell
    very fast
    Its the one with the light, the remote i bought is from same year tacoma. it does not want to program,. its like at the end steps i push the button the doors lock 4 times every time i push the button down, open the door and nothing.
  5. Feb 24, 2011 at 2:52 AM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    if you can't get that too work. i just installed a audiovox Model # AA-925. you can find it on Amazon for 22.00.
  6. Feb 24, 2011 at 5:44 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    My brother had the same problem with his highlander. After going through the process 3 or 4 times, after he didn't get the confirmation, he just held down the two buttons out of frustration and it worked. Seems silly, but it might be worth a shot. Good luck.
  7. Feb 24, 2011 at 9:20 AM
    spidy3
    Dom
    Upstate NY
    10 DC TRD Off Road
    you can have different keyless systems in the same year and model vehicle. Have to find out if remote your trying to program goes with keyless system in vehicle
