Quick question concerning leaf springs!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by zeeya2000, Mar 27, 2011.
  1. Mar 27, 2011 at 6:32 PM
    zeeya2000
    zeeya2000 [OP] Cajun Taceaux
    Craig
    Lafayette, Louisiana
    Bad-Ass PreRunner
    Flowmaster super 10 series turndowns/ Volant CAI system/ Alpine deck, Alpine bass speakers throughtout with tweeters, Alpine PLT-5 Sub/ Blacked out front bumper and door handles/ 5% and 20% tint/ Bilstein 5100 adjustable shocks all the way around with a 1.5'' block lift in the rear/ also removed my running boards and mudflaps/ Blacked out badges - TRD windshield banner - TRD third brake light cover (all courtesy of SockMonkey)
    hey guys im curious to know why the heavy loader leaf spring (one all the way to the bottom) is placed upside down? curving down instead of up which would support the other leaf springs.
    i looked at several other vehicles sitting around and all of theirs were right side up. (not toyota tacomas)
    i do have trouble carrying loads could this solve the problem?
    what would be the down fall of turning the heavy loader spring right side up? curving up towards the leaf springs
  2. Mar 27, 2011 at 6:45 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    yes i know this looks funny with the front not being leveled out but this is what happened when i turned my bottom leaf right side up
  3. Mar 27, 2011 at 6:48 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    bump....... anyone???
  4. Mar 27, 2011 at 6:48 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    That leaf is your overload spring so that the rest of the pack won't go over negative arch too much when loaded down. I think some people have run it upside down but I can't comment too much on it myself. Looks like it worked for you...fwiw I don't really like a level truck...needs a slight rake
  5. Mar 27, 2011 at 6:50 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    i agree it does need some tilt but not as much as it does in that picture the front deffinately needs a 2" spacer
  6. Mar 27, 2011 at 6:53 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Damn..."Got Rake?"
    And I agree with malander
  7. Mar 27, 2011 at 6:56 PM
    malander
    max
    01 limited trd 4x4
    Meh it is a lot of rake but it doesn't look too bad. Bigger tires will look great and will fill out the rear wheel wells nicely
  8. Mar 27, 2011 at 6:56 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    hah yea it made a big difference. im jus wondering if that would mess stuff up
  9. Mar 27, 2011 at 6:57 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    33's would look awesome
  10. Mar 27, 2011 at 7:03 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    any other insights????
  11. Mar 27, 2011 at 7:10 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
  12. Mar 27, 2011 at 7:13 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
  13. Mar 27, 2011 at 7:16 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
  14. Mar 27, 2011 at 7:19 PM
    zeeya2000
    Craig
    Bad-Ass PreRunner
    maybe so
  15. Mar 27, 2011 at 7:32 PM
    blenderdriver
    blenderdriver Inflamed Member
    Todd
    texAss
    Magnetic Grey 2010 4 Door, 4X4, Long bed.
    Powered by one tailgate mounted CFM56–7 engine. The engine is a dual–rotor, axial–flow turbofan engine capable of producing 27,000lbs of thrust. Why yes, my tailgate is slightly bowed in.
    For what it's worth... I had a '96 Tacoma extended cab 5 speed manual V6 4X4, lived in the mountains of Colorado, did lots of off roading in Colorado and Utah, broke leaf springs a couple of times, the last time I had it repaired, the guys at the spring place replaced the broken leaf, I had them add a leaf and they reassembled them with one of the heavy loader mounted up and the other mounted down. Didn't pay too much attention to it being upside down once I got it back, smart huh.. I drove it like that for about 4 years, with no problems. Buddy of my dads had a lift and we flipped the upward facing heavy loader down to it's original position I couldn't notice any difference other than if you really looked, right side sat a little higher in the back. Maybe others might have had a different experience??
  16. Mar 27, 2011 at 7:32 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    So does the truck ride any rougher because of turning the leaf around?
  17. Mar 27, 2011 at 8:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you add those lift blocks when you flipped the overload leaf or were they on there before? Take those blocks out and you'll be level (or closer to) again.
  18. Apr 11, 2011 at 7:01 AM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    I flipped over my overload last week and have had no problems. Drove 100 miles round trip with streetbike in back and it drove nice. And it add 1" lift to rear also. Heres a pic
  19. Apr 11, 2011 at 8:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Looks like all you've done is make the overload part of the leaf pack instead of only being used with a heavy load in the bed. Shouldn't do anything adverse but will probably make it ride like a dump truck. It's like putting in a really stiff AAL.
  20. Apr 11, 2011 at 11:27 AM
    Tacoma of Souls
    Tacoma of Souls Member
    Nova Scotia, Canda
    QFT. you just sprung your rear suspension a little bit more.
