-   -   Suspension questions... (http://www.tacomaworld.com/forum/1st-gen-tacomas/154266-suspension-questions.html)
redrckhiker 04-28-2011 08:29 PM
So, made up my mind I'm gonna do the OME 880/881's to go with my 5100 Bilsteins; I may want a 1" lift, but not if that means I have to do UCA's. If I go with the 880's with the 1" lift, do I need to do the UCA's? If I stick with the 881's I assume their stock, standard height springs? So in short, I may do like a one inch lift, but the UCA stuff may be more than I can do, not sure. If I can do the coil/shock replacement, if I need to do the UCA's, is this significantly more difficult?
Max-4_Yota 04-28-2011 08:31 PM
Your not gonna need new uca's, ive got a 3" lift and my stock uca's are fine
MTgirl 04-28-2011 08:41 PM
OME 881's with 5100's set on zero...2" lift and all is good, no need to change the UCAs
